Will Windows 7 run on an ASUS P5V800-MX?
Postby monkey100 » Mon Nov 15, 2010 2:30 pm
64 bit and 32 bit WIN7 installer hangs when the blue "desktop" comes up. Nothing after that. XP-MCE is currently running fine for many years. Have tried removing all cards, etc.
Is there a minimum BIOS level for WIN7?
Intel Pentium D 840 3.2GHz , 2GB DDR (maxed out)
If this will never work I'll be looking for reccomendations for a reasonably priced board.
Thanks in advance.
monkey100
Postby Big Jake » Mon Nov 15, 2010 11:13 pm
I have run win 7 32 bit on two different socket 478 boards. Make sure your BIOS is current.
You may find this helpful.
http://www.microsoft.com/downloads/en/d ... 97c146af15
Big Jake
Postby bdub » Tue Nov 16, 2010 6:48 am
i remember tell of the d840 being quite an overclocker. do you have it running at stock settings? if not, try backing it down.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby Hardware Junkie » Tue Nov 16, 2010 12:19 pm
No reason why it shouldn't run Windows 7. Its a 64bit processor as well.
We've just finished upgrading a bunch of scrap Pentium 4 workstations with Windows 7, 1.5-2GB RAM minimum. And they all worked fine.
Could be a built in driver problem.
One thing you could try is switching SATA Emulation from AHCI to IDE, but that usually only causes problems during installation, not when its finished.
Could try booting into SafeMode and allowing the drivers to finish that way.
There is a 2009/02/13 beta bios update but I would only do it as a last resort.
Return to Operating Systems
