It is currently Sun Sep 23, 2018 11:53 pm
PostPosted: Fri Sep 20, 2002 1:26 pm
I'm setting up a KT333 Dragon Lite motherboard with an Athlon 2100+ processor w/266MHz FSB. According to my mobo manual, I set the CPU frequency to 100/133MHz depending on the FSB of my CPU. So my question is: what is the corresponding CPU frequency for this processor? Forgive what may be sheer stupidity on my part, as this is my first time building a computer.
Thanks,
Badmelonfarmer
PostPosted: Fri Sep 20, 2002 1:37 pm
set it to 133 so it will run at 266FSB and register your cpu at 2100xp instead of something underclocked.
Hey, if you want me to take a dump in a box and mark it guaranteed, I will. I got spare time.
PostPosted: Fri Sep 20, 2002 1:40 pm
Just to add on to what lil boi phreak said, basically you set it to 133 so the board can double it to 266 to match the speed of your processor.
