It is currently Sun Sep 23, 2018 1:15 am
PostPosted: Wed Sep 18, 2002 6:02 am
I have the above Mobo and have downloaded the following files to upgrade the BIOS: ABITFAE.BAT, AWDFLASH.EXE and the KG7_68 BIOS file.
However my OS is Windows XP Pro, and I haven't been able to find the precise procedures/instructions on how to go about this. And there is no C: or A: prompt to go too.
Does anyone know where I can get the info for upgrading the BIOS on WinXP Pro systems.
Regards John
PostPosted: Wed Sep 18, 2002 7:36 am
http://www.mirrors.org/archived_softwar ... tdisk.com/
DR DOS 7.X bootdisk. Download and execute, so you have a bootable floppy. Then copy those three files to that floppy.
Boot from floppy, there's your A:>\ prompt.
 Post subject: RE YOUR FEEDBACK
PostPosted: Wed Sep 18, 2002 3:05 pm
Thanks for the prompt response.
I will do as suggested and get back to you if needed.
John
[quote="evasive"]http://www.mirrors.org/archived_software/www.bootdisk.com/
Boot from floppy, there's your A:>\ prompt.[/quote]
PostPosted: Thu Sep 19, 2002 11:21 pm
Regards John
 Post subject: RE BIOS UPGRADE KG7-RAID
PostPosted: Fri Sep 20, 2002 5:06 am
Thanks for this feedback. BIOS successfully upgraded.
