It is currently Sun Sep 23, 2018 4:36 am
 Post subject: Wrong cpu speed in bios
PostPosted: Fri Sep 13, 2002 10:43 pm
I just flashed my bios and now in the bios my cpu speed is wrong. I have a 2000xp and a asus a7v333 and instead of saying that the cpu is 1670 it says it's 1733 and the only other thing's I can change it to are 1300 or 2167, should I be worried?
PostPosted: Sat Sep 14, 2002 12:25 pm
Something is set wrong. Look for an FSB or Multiplier setting aswell...
PostPosted: Sat Sep 14, 2002 10:29 pm
Ok, the multiplier is at 12.5 and the FSB is at 133 I hope they dont need changed because they are grey and I cant change them.
PostPosted: Sat Sep 14, 2002 11:09 pm
Did you load setup defaults after you flashed the BIOS? If not do that then setup your BIOS again (to your custom settings). If it wont let you do that then clear the CMOS manually and then set it up again.
PostPosted: Sat Sep 14, 2002 11:15 pm
In asus probe under information it say's there that the current cpu speed is 1666 should I still do what you have said?
