Alternative to $ bios upgrade?
Postby jbeiter1 » Fri Sep 13, 2002 7:55 am
I wanted to upgrade HDD and bought an 80g maxtor. okay cart before horse I'll take the lumps. Now looking to complete install and need help with options for a bios upgrade. I found that eSupport will sell me one that will allow up to 130g hdd support. Are there other options?
ran bios agent and here's what I know;
Bios Date: 06/25/98
Bios Type: Award modular bios v4.51PG
Bios ID: 06/25/98-SiS-5598-W877F-2A5IIG5CC-00
Bios Eval: Packard Bell FR500 Bios Version v1.03
Chipset: SiS 5597 rev 16
Superio: Winbond 877TF (use 87h) rev 0 found at port 3F0h
Found that the G5 designates a 'gvc' motherboard and that I have the Cyrix M-II 300 processor. However gvc.com is no help
Any help is much appreciated.
jbeiter1
Postby Hardware Junkie » Fri Sep 13, 2002 11:17 am
Here is the latest bios:
http://support.packardbell-europe.com/s ... 0.asp?c=ap
Chances are it won't help you support an 80GB drive.
You might want to consider using an ATA controller card in the system.
Postby vick » Fri Sep 13, 2002 12:21 pm
hey i bought myself a maxtor 80gb recently too it has a jumper setting so if your drive is not dected by the bios it can fool the bios into thinking its less then 30gb (or whatever the limit may be) then u can just load the software provided and it works like a charm!..you should try it..if the bios upgrade doesnt help you
hth
Vick
vick
Postby Hardware Junkie » Fri Sep 13, 2002 12:24 pm
The software your talking about is a drive overlay type of software. That is another option for you and might be a good idea.
Good post vick. 8)
Postby Denniss » Fri Sep 13, 2002 2:49 pm
Or jump to www.wimsbios.com into the discussion Board and let your 4.51PG based Bios be patched for HDD up to 128GB !
Denniss
Postby jbeiter1 » Sat Sep 14, 2002 2:14 pm
Dudes Thanks for the quick replies! I haven't a clue as to
drive-overlay-ware but as you suspected the bios at the europe pb site is 1998 and may not be of much help now, cept if I slip and need a recovery!
So... An ATA adaptor or a software workaround...
1 Costs $$ and 2 costs disk access time forever, yes?
Thanks for the lowdown looks like I'll look at the costs for an ATA card, in theory that sounds like the way to go. however if everything is cost equivilent what are the technical pros/cons?
Also what's important in matchin a bios update? everything? I mean MB/Processor/Bios Manufacturer/...
Thanks again your help is invaluable. Joe.
jbeiter1
Postby Hardware Junkie » Sat Sep 14, 2002 3:02 pm
With an ATA Adapter (costs maybe 20-35 bucks) it should pick it up as the main boot device - you may have to disable the onboard IDE channels to make it work though...
Drive Overlay software doesn't slow down access time too much. Your independant hard drive manufacturer would have this information and the software to download
BIOS Updates can only be developped by the manufacturer of the motherboard. In some other cases a general bios can be obtained by Unicore (http://www.mrbios.com) aswell.
Postby Denniss » Sun Sep 15, 2002 2:34 am
Rainbow from www.wimsbios.com has developed a small program to fix the 32GB and 64GB BUGs in Award 4.51PG Bios and offers his help in the discussionboard there .
He and the other moderators there helped many people to get their new big size HDD to work and this is FREE !
And this Bugfix does not cost performance .
Denniss
Postby jbeiter1 » Mon Sep 16, 2002 5:04 am
Re: wimsbios, I had looked and not found something specific to the gvc mobo but, I've not asked over there. That was part of the reason for the question on 'how specific does a bios fix need to match' in my last post here.
Are bios's tweaked for specific applications like mobo/processor/peripherials?
Are there any other, likely, bad/unpleasant outcomes from using a bios patch from other than the mobo oem?
I'll see what I can find over there. Thanks for the leg up.
Joe.
jbeiter1
Postby Denniss » Mon Sep 16, 2002 5:19 am
You have to post in the discussion board and the moderators will try to patch your bios - the nonworking IDE detect routines will be replaced with working ones .
Denniss
Return to BIOS
