It is currently Mon Sep 24, 2018 12:05 am
PostPosted: Thu Sep 12, 2002 6:14 pm
Where can you find out what each catagory in bios does such as;
OS select for dram>64mb
pc latency timer
16bit I/O recovery time
I am having a problem with data transfer rate to my mp3 player and also converting mp3 to wave. for some reason things are working slower than usual. I just installed a new bios and need to know what all the settings should be. I am having to burn my cd's at 4x instead of 12x for some reason the data is not being transfered fast enough. I run 512 mb of ram but sometimes it seems as though it runs out of memory. something must be set wrong to cause these problems Tom T. :? :? :?
PostPosted: Fri Sep 13, 2002 10:04 am
http://www.motherboards.org/forums/viewtopic.php?t=7136
