a7v333 flash question
Postby twixel » Thu Sep 12, 2002 1:40 pm
I just went to flash my BIOS using the asus post flash utility, I typed in the file name and then it said the following:
1. update main BIOS area (Y/N)?
2. update boot block area (Y/N)?
which one do do i hit Y for?
I also went to it with asus update and went to load the file from my documents then it said the file was correct flash/exit. I was going to click flash but it seemed to be too easy, should I just do it this way instead?
Thank's
twixel
Postby twixel » Thu Sep 12, 2002 2:28 pm
Ok just went back to give it another go and it say's this above that other stuff
bios version: a7v333 boot block
So common sense is telling me to press no to update the main bios area and yes to update boot block area, but i still dont want to make a mistake because im a flashing virgin.
twixel
Postby twixel » Fri Sep 13, 2002 5:42 pm
Ok ive it done now. On the asus website I couldnt find anything about the asus post flash utility, thats cos its called that in the manual on the website its called ezflash :roll:
So you just press yes to everything to flash it just in case anyone is wondering.
So now im ready for a 2600xp :D :D when I get the money :cry: :cry:
twixel
Return to BIOS
