Gigabyte 8IEXP
Gigabyte 8IEXP
Postby xyz » Fri Sep 06, 2002 10:59 am
I have bought a PC with a GA-8IEXP motherboard.
At page 29 of the Ga-8IEX Series User’s manual (technical reference) the “set supervisor/user password” function is explained. This function seems not operative on the BIOS F5 or F6 or F7 version. In fact at line 13 it is written: “if you select “System” at “Security option” in Advance Bios Feature Menu ……..”. However in Advance Bios Feature Menu the Security option is not present!
Have I not understood?
[/b]
xyz
Postby evasive » Sun Sep 08, 2002 12:43 am
Is there a Set Supervisor Password option present?
Postby xyz » Sun Sep 08, 2002 10:39 am
yes; the set supervisor password option is present; I have created this password for BIOS access; it is no longer possible to cancel them!!!!
xyz
Postby evasive » Sun Sep 08, 2002 11:24 am
change supervisor password, enter old password, hit enter on the new password and once again on the confirm new password, that should clear it.
Postby xyz » Mon Sep 09, 2002 1:03 am
It is the classic method, but here it works not!
xyz
Postby Hardware Junkie » Mon Sep 09, 2002 11:06 am
Then clear the CMOS by using the jumper or pulling out the battery and it should be whipped clean...
Return to BIOS
