Help on PC chips M741LMRT MB BIOS
Postby again » Wed Sep 04, 2002 7:38 pm
I'm looking for a PC Chips M741LMRT Motherboard.
I failed when I update the BIOS of this Motherboard. I need a same MB but in working condition to save my MB. If you have this type of MB and willing to help me, please let me know. I will send you the FLASH ROM of the MB.
again
Postby Denniss » Thu Sep 05, 2002 9:24 am
Is your board completely dead or do you have some floppy activity ?
Denniss
Postby again » Fri Sep 06, 2002 6:05 am
There's no flopy disk activity. Thank you Dennis for your concern. Right now I think I'd better give up.
again
Postby Hardware Junkie » Fri Sep 06, 2002 12:04 pm
Before you give up. Might want to check out Badflash to buy a new chip...
Postby evasive » Fri Sep 06, 2002 12:12 pm
Question. Does your current bios chip have a marking ASD on it somewhere?
Postby suporteru » Fri Apr 09, 2010 1:52 am
i need help,wich is the maximum size of the hdd,this mb support? :wink: because i want to buy one hdd and i need some tips..thanks!@ :wink:
suporteru
Postby evasive » Fri Apr 09, 2010 4:02 am
The largest disk I have seen reported was 80GB and for that you need to set the parameters manually. I think the theoretical maximum is 128GB per disk.
If you want anything larger or SATA disks instead of IDE/PATA, you need to buy a seperate add-in controller card with bios.
Return to BIOS
