CPU speed is not stable
Postby kayaker4 » Mon Sep 02, 2002 10:14 am
Here are my stats:
AMD Athlon XP 1800+
Asus A7V266-E
Award Medallion Bios ver. 6.0 Rev. 1004B
The Problem:
Upon bootup, bios appears and cpu speed has been decreased by the bios. Instead of 1533 Mhz, it insists on running at 1150 Mhz. I returned to default settings but it is now hanging up once I get into the bios to check that all is ok. Another weird symptom I got was a **one-time** only post code of a series of beeps, which Award says is bad ram (I have two 256 MB sticks of ddr memory). System reads all 512 MB.
I don't want to upgrade the bios unless absolutely necessary. Does anyone know something technical about this bios, the amd xp cpu series or this motherboard which could explain this behavior? I am exhausted from searching....
Please reply here. Thanks!
Postby afodorcei » Mon Sep 02, 2002 10:41 am
Please go back to your bios and settle for 133 CPU speed 133-133 not 100
look up and you will find :D
Return to BIOS
Users browsing this forum: MegaIndex.ru [Crawler] and 1 guest
