My bios is erased..?!
Postby LisbonBoy32 » Tue Aug 27, 2002 1:08 pm
:cry:
I need help! I was trying to update my Bios, but by error i flash it rong.
Now, even at the monitor screen nothing appears, only a beep.
I try to find any kind of update, but nothing result.
Do i need to buy a new chip, and put it at the computer?
The MotherBoard i use is a DFI, model CA61 - Revision B1.
The Chip inside the Computer is the follow:
The manufacter is:
WINBOND
and theres a seal whit this reference:
AWARD - 1998 - PCI/PNP 686
and this number: 243948423
At the top of the chip there are this references:
W29CO20C-90B
016AI200873901SA
Can someone tell me what to do? Is it yet possible to put the bios right?
And if not, where can i buy the correct one?
Thank you.
João
Lisbon - Portugal
E.Mail: joao.agostinho@iol.pt
[/b]
LisbonBoy32
Postby Hardware Junkie » Tue Aug 27, 2002 1:26 pm
A couple of things to try.
If you have another computer you could try "hot flashing" it.
Check http://www.wimsbios.net/phpBB2 forums for how this works. They have a thread there deticated to this kind of stuff
You can also contact Badflash.com for a new preprogrammed chip.
Return to BIOS
Users browsing this forum: Bing [Bot] and 4 guests
