where to get bios update for a EMACHINE
Postby wgreathouse » Mon Aug 26, 2002 10:48 pm
ONLY INFO ON MOBO AS FAR AS MFG. GOSE IS THAT IT'S FROM A CO.
CALLED {TG_FLORIDA } THE ONLY INFO I CAN GET FROM BIOS STRING IS THAT IT'S FROM {AMI}
HERES THE INFO I HAVE ON IT :( :(
AMIBIOS Motherboard Manufacturer Identification
Version 1.2 (02/07/2001) Copyright 2000 American Megatrends, Inc.
This file has recorded information useful in identifying the manufacturer
of this motherboard. The information is listed below:
An AMIBIOS ID String Was Detected:
62-314E-123199-00101111-071595-440LX
| | | Chipset/BIOS Info
| | Manufacturer ID
| Version Information
Processor & BIOS ROM Information
The Manufacturer Code Detected (3199) Does Not Have A Database Entry.
The Following AMIBIOS Project Tag Was Found: _TG_FLORIDA
wgreathouse
Postby evasive » Tue Aug 27, 2002 12:00 pm
Postby embj » Tue Aug 27, 2002 2:50 pm
I have an Emachines BIOS from AMI. It is for a TG_Florida mobo. Just for your information TG_Florida is made by TriGem which is a Korean mobo. I do not know if this BIOS I have will work or not. I put in my Etower 466is with the 466mhz Celeron CPU on the Intel 440LX. If you want it, e-mail me. Again I am not sure if it will work on your comp. Try at your own risk.
***Try to go to www.trigem.com and find their e-mail address. Ask them about the BIOS for your Emachines.*** Good luck!!! :D
embj
Postby evasive » Wed Aug 28, 2002 12:23 pm
Return to BIOS
