HELP NEED BIOS UPDATE
Postby sicko » Sat Aug 24, 2002 5:47 pm
I have found it. A friend of a friend has the same MB as I do. He has given me a 2D version but with a different flash utility. It looks like I had a bad program. Thanks for all your trouble. I'll try to help anyone who has some kind of the trouble.
sicko
Postby boheemee » Sun Aug 25, 2002 12:40 am
boheemee
Thanks for the suggestion but....
Postby sicko » Sun Aug 25, 2002 4:38 pm
Yes I have tried there, but I have a BIOS version 2A and the website you are suggesting has only version 2D available.
Thanks anyway.
sicko
Postby profofpcs » Sun Aug 25, 2002 4:52 pm
maybe its me but wouldnt 2D be the latter of the versions?
profofpcs
Postby mikemcc62 » Tue Aug 27, 2002 12:41 pm
ACORP 6BX81 Ver:2b slot one moteherboard with INTEL BX440 chipset
updated from ACORP 6BX81 Ver:2a
go here
http://www.acorp.com.tw/Common_Txt/BIOS/BINTEL.asp
mikemcc62
Good point but...
Postby sicko » Tue Aug 27, 2002 1:52 pm
cacrusn wrote:maybe its me but wouldnt 2D be the latter of the versions?
I have tried 2D version and it doesn't work. That is the same 2D version from the official website. You are right in your comment, but I think there is somthin' different here.
sicko
Postby evasive » Tue Aug 27, 2002 1:55 pm
Post the entire 2A69K string. We'll go for another hunt. Yippie 8)
Return to BIOS
