It is currently Tue Feb 19, 2019 5:06 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
PostPosted: Tue Feb 12, 2013 8:09 pm
rascard2007 wrote:
the error can be due to a bad memory stick, check it
other errors to. That was just the most popular. And stuff crashes a lot. The memory was pretty much brand new, if I got bad memory ima be pissed. How do you know?
PostPosted: Tue Feb 12, 2013 10:30 pm
use this:
http://www.memtest.org/
PostPosted: Wed Feb 13, 2013 6:50 am
You also might want to test the sticks one by one, or in pairs if required by your board. If a stick fails, try in different slots. You could have a bad ram slot on the board or might not be seated correctly.
PostPosted: Wed Feb 13, 2013 11:21 am
"Page fault in non-paged area" could be the result of a module going bad, or more likely the supply voltage is too low. Ensure the modules used are in compliance with what is recommended. Your mobo uses a memory controller that is embedded in the CPU die.. and requires a lower voltage source (under 2 volts). If the level is not proper for the memory modules, paging will fault. The BIOS should have a provision to increase the memory control voltage a bit. But be careful, as too high can cause damage to the CPU as well as memory!
PostPosted: Wed Feb 13, 2013 1:29 pm
have you checked the board for bad capacitors... bulging, or oozing?
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
