asus p8h67-M-LE bios trouble
Postby Takkie1970 » Sun Jan 15, 2012 1:48 pm
Hi,
New here one this forum. Used the seach but could not finfd answers.
I have a MB as stated above with a I3 2100 cpu, 4 gb transcend sdram and 3 WD sata drives.
Want to use this hardware to build an unraid server. Problem is that although I see HD's in bios, I cannot see them in linux.
Strange thing is that I cannot switch from ide mode to AHCI mode in this efi bios. Am using latest version but changing from ide is greyed out. Am I overlooking something, switched sata ports. No joy. Does anyone know what else I can try?
Hope someone can help
Takkie1970
Postby Mr T » Mon Jan 16, 2012 1:41 am
Welcome to the motherboards.org...
What size and type (SATAI,SATAII or SATAIII) are the hard drives?
Postby evasive » Mon Jan 16, 2012 2:46 am
Is that a rev 3.0 board? otherwise this could be one of the flawed Cougar point chips causing all sorts of trouble.
Postby Takkie1970 » Mon Jan 16, 2012 5:47 am
Mr T wrote:Welcome to the motherboards.org...
Thank you for welcoming me.
They're (2) WD10EVDS drives and (1) WD15EADS drive.
Hope this helps, I have a HBA and when I plug them in there I can see them in linux aswell. So I am more and more thinking in the dirtection of the bios. But I could be wrong, maybe it is cables?
Takkie1970
Postby Takkie1970 » Mon Jan 16, 2012 5:48 am
evasive wrote:Is that a rev 3.0 board? otherwise this could be one of the flawed Cougar point chips causing all sorts of trouble.
No it is a Rev 3.0 board.
Takkie1970
Postby Mr T » Mon Jan 16, 2012 6:19 am
Also forgot to ask waht linux distro are you using...? If it is an older kernel, it may have issues with the SATA controller or larger sized drives...
Postby Takkie1970 » Mon Jan 16, 2012 6:45 am
Mr T wrote:Also forgot to ask waht linux distro are you using...? If it is an older kernel, it may have issues with the SATA controller or larger sized drives...
Am using (at leat that was the plan) unraid wich is a slimmed down slackwaredistro especially used for media streaming. They should support these sized drives. In the newer beta versions it shoudl even support 3 and 4 Gb drives.
Ubuntu 11.1 did not show any drives except the usb flash cardreader used as startup for unraid. Do not know if you are familiar with unraid?
Hope this helps.
Takkie1970
Postby Mr T » Mon Jan 16, 2012 6:59 am
No I am not familiar with unRAID, not a distro I have needed to use.. From what you are saying, it looks like an issue between the motherboard and hard drives... I would
Clear the CMOS and set the BIOS up again
Change the SATA cables
Try 1 drive at a time
Also is your PSU up too it...? For what you are doing, 500w minimum...
Postby Takkie1970 » Mon Jan 16, 2012 7:13 am
Mr T wrote:No I am not familiar with unRAID, not a distro I have needed to use.. From what you are saying, it looks like an issue between the motherboard and hard drives... I would
Will try that, clearing CMOS it is probably a dipswitch?, will check manual.
Will try one drive at the time. Hope this helps. Ta for the help. In one day I have had more response from this forum than other forums I asked for help, thank you.
Takkie1970
Postby Mr T » Mon Jan 16, 2012 7:15 am
You are welcome, you are lucky I am not working today..... :D
Return to BIOS
