It is currently Wed Jul 17, 2019 1:08 am
PostPosted: Thu Dec 29, 2011 2:46 pm
Chaintech 6BTM-M101 AGP
04/09/98-i440BX-W977TF-2A69KC39C-00
Award Modular BIOS v4.51PG
04/09/1998
Pentium II-MMX at 233MHz (CPUID:634, MicroCode ID:0033)
Award Plug and Play BIOS Extension v1.0A
I have 6BTM0C23.bin and 6BTM0505.bin
any preference which to use?
also, intend to use Uniflash.exe (as opposed to flash753.exe or Awdflash)
FWIW, it recognized 4 ea 256MBs!! (0.917Gig ;-)
Having problems loading XP SP2 - didn't seem to care for the Riva 128ZX AGP (no XP drivers found...yet), trying an S3 PCI next
...thanks in advance
 Post subject: "Technical Information:"
PostPosted: Thu Dec 29, 2011 2:52 pm
getting
stop: 0x0000008E (0xC0000005, 0x8056E529, 0xF781C95C, 0x00000000)
PostPosted: Thu Dec 29, 2011 3:44 pm
associated with backdoor viruses or ram problems.
the 0505 is about 5 months newer 05/05/2000, the other is dated 12/23/1999
when flashing, please put in just one of the original known working memory sticks only. After flashing the new bios you can try the 256MB sticks again.
PostPosted: Thu Dec 29, 2011 4:11 pm
many thanks... again ;-)
had swapped out the 256ers with 128s, just for fun...
install is running along quite smoothly now
will re-try the 256s (one at a time) after flashing BIOS
PostPosted: Thu Dec 29, 2011 4:13 pm
FWIW, the 256s are "lo-density"(?) i.e. 16-chip (8 per side)
...or am I chasing rabbits? (again)
PostPosted: Fri Dec 30, 2011 2:32 am
You did well to get lo-density modules:
http://homepage.hispeed.ch/rscheidegger ... rted_on_my
You may have pulled a rabbit out of the hat here :)
