It is currently Tue Dec 18, 2018 7:57 am
PostPosted: Fri Dec 31, 2010 11:49 am
Hi My new PC gigabyte GA-MA785GM-US2H Athlon IIx4 630 4 gigs corsair XMS 2 6400
CPU-Z core speed 2812 mhz-buss 200.9-core voltage 1.45v-HT link 2009
multiplyer x 14
I set it up in case and installed XP pro, no problem. I havent used it much and seems to run ok. In the MB intelligent tweaker its set on normal and the everything auto. I didnt set anything, are there any requried or better settings i should make. I just use thi rig to make slide shows.edit video and some photo stuff. The other bios i understood just the tweater was hard to set even after reading the manual. Thanks Bob
PostPosted: Mon Jan 03, 2011 2:23 pm
You don't really need to play around with this unless you want to overclock your computer
PostPosted: Mon Jan 03, 2011 2:32 pm
Ok thanks Bob
