Need Help on Bios update
Postby gesa » Wed Sep 23, 2009 7:17 pm
hi
i currently have spare 3GHZ Intel CPU with 1mb cache and 800 FSB. My current motherboard bios level is P08, if i updated to p13 level will it work in my Intel Desktop Board D865GLC ( last 3 numbers of board revision is 404)
its the cpu listed here http://www.intel.com/support/motherboar ... 026965.htm
Pls advise
gesa
Postby fussnfeathers » Wed Sep 23, 2009 7:52 pm
Yep, it'll work with the latest BIOS.
Faster than the speed of snot
fussnfeathers
Postby evasive » Wed Sep 23, 2009 9:10 pm
Hang on, what model do you have?
C27498-406 or later
C27499-406 or later
C27500-406 or later
C28903-405 or later
C28906-405 or later
C28909-406 or later
C32156-405 or later
C31110-404 or later.
only if you have the C31110-404, if it's one of the others, bad luck, it won't work. Told this before.
Postby gesa » Wed Sep 23, 2009 11:13 pm
evasive wrote:Hang on, what model do you have?
C27498-406 or later
C27499-406 or later
C27500-406 or later
C28903-405 or later
C28906-405 or later
C28909-406 or later
C32156-405 or later
i have C28906-404, even with this number, if i update bios to p13 will this 3ghz 1mb 800ghz fsb still work?
gesa
bios update
Postby gesa » Wed Sep 23, 2009 11:16 pm
i fear if i go to update the bios from intel website, my computer may get corrupted if mistake made and so is there any safer way to update bios?
Also, what would be the benefits of updating bios from P08 to P13 ?
gesa
board number
Postby gesa » Wed Sep 23, 2009 11:33 pm
gesa
Re: board number
Postby evasive » Thu Sep 24, 2009 12:54 am
gesa wrote:i have C28906-404, even with this number, if i update bios to p13 will this 3ghz 1mb 800ghz fsb still work?
it is not "C28906-405 or later" so no, whatever bios you flash, it will not work. the hardware cannot handle the processor.
Re: board number
Postby fussnfeathers » Thu Sep 24, 2009 4:23 am
Right, I missed that bit.......happens when I post at stupid hours of the morning. :oops:
Your motherboard can't supply the power needed to run a Prescott, even with a BIOS update, the hardware just isn't there.
fussnfeathers
prescot?
Postby gesa » Thu Sep 24, 2009 5:09 am
so does this mean my motherboard cannot run any presscot processor, or are you only refering to the 3ghz with 1mb cache and 800fsb ?
gesa
Re: prescot?
Postby fussnfeathers » Thu Sep 24, 2009 9:22 am
gesa wrote:so does this mean my motherboard cannot run any presscot processor, or are you only refering to the 3ghz with 1mb cache and 800fsb ?
Correct, your motherboard will not support the Prescott core, only Northwood.
fussnfeathers
Return to BIOS
Users browsing this forum: AhrefsBot [Bot] and 3 guests
