It is currently Sat Oct 20, 2018 1:42 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Sep 21, 2009 3:30 am
OK folks...I've been racking my brain, and I'm thinking my only option at this point is to hexedit the intel bio image to get this to change...Anyone have another idea?
I have a Emachine T3882 System...Attached is the CPU-Z report.
The DMI shows Gateway, but the actual motherboard (even the print onboard) shows no sign of anything other than a pure intel board.
I have tried all three intel bios update methods (win,dos,emergency bio) and the closest i got is with the emergency bio that reads the file off of the cd and shuts down, but when restarting, the bios is only reset and not updated.
I've heard that gateway cripples the intel emergency bio update, but i'm not sure (it doesn't work the way it should).
I would love to have a way to change the mobo bios id to update to the pure intel mobo bios. I would see this as my best option.
bios id's...
current gw = BF86510A.15A.0085.P20.0412152353
new intel = BF86510A.86A.0077.P25.0508040031
I'm not worried about any windows oem bios activation values, I don't use onboard sound or onboard video.
Anyone know the best solution for my issue?
CPU-Z TXT Report
Binaries
CPU-Z version 1.52.2
Processors
Number of processors 1
Number of threads 1
APICs
Processor 0
-- Core 0
-- Thread 0 0
Processors Information
Processor 1 ID = 0
Number of cores 1 (max 1)
Number of threads 1 (max 1)
Name Intel Celeron 335
Codename Prescott
Specification Intel(R) Celeron(R) CPU 2.80GHz
Package (platform ID) Socket 478 mPGA (0x2)
CPUID F.4.1
Extended CPUID F.4
Core Stepping E0
Technology 90 nm
Core Speed 2793.1 MHz
Multiplier x FSB 21.0 x 133.0 MHz
Rated Bus speed 532.0 MHz
Stock frequency 2800 MHz
Instructions sets MMX, SSE, SSE2, SSE3
L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 12 Kuops, 8-way set associative
L2 cache 256 KBytes, 4-way set associative, 64-byte line size
FID/VID Control no
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01001006h
Max CPUID level 00000005h
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 2, U, 256 KB, 1 thread(s)
Cache descriptor Level 1, T, 12 KB, 1 thread(s)
CPUID
0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x00000F41 0x00010800 0x0000441D 0xBFEBFBFF
0x00000002 0x605B5101 0x00000000 0x00000000 0x003C7040
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000121 0x01C0003F 0x0000001F 0x00000000
0x00000004 0x00000143 0x00C0103F 0x000001FF 0x00000000
0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
0x80000002 0x20202020 0x20202020 0x20202020 0x20202020
0x80000003 0x65746E49 0x2952286C 0x6C654320 0x6E6F7265
0x80000004 0x20295228 0x20555043 0x30382E32 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x01004040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00002024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0x00000017 0x000A0000 0x00000000
MSR 0x0000002C 0x00000000 0x15110715
MSR 0x000001A0 0x00000000 0x20840089
Chipset
Northbridge Intel i865P/PE/G/i848P rev. A2
Southbridge Intel 82801EB (ICH5) rev. 02
Memory Type DDR
Memory Size 1024 MBytes
Channels Dual
Memory Frequency 166.3 MHz (4:5)
CAS# latency (CL) 2.5
RAS# to CAS# delay (tRCD) 3
RAS# Precharge (tRP) 3
Cycle Time (tRAS) 7
Performance Mode enabled
MCHBAR I/O Base address 0x0FECF0000
MCHBAR I/O Size 256
MCHBAR registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 08 10 10 10 10 10 10 10 00 00 00 00 00 00 00 00
10 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 85 0D E7 56 C6 42 14 00 71 62 50 20 81 83 63 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 30 08 04 00 08 04 41 00 08 04 41 00 28 08 02 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR
Manufacturer (ID) Micron Technology (2CFFFFFFFFFFFFFF)
Size 512 MBytes
Max bandwidth PC3200 (200 MHz)
Part number 16VDDT6464AG-40BC4
Serial number 1A51B1D6
Manufacturing date Week 06/Year 04
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
Nominal Voltage 2.50 Volts
EPP no
XMP no
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 2.0-2-2-6-0 @ 133 MHz
JEDEC #2 2.5-3-3-7-0 @ 166 MHz
JEDEC #3 3.0-3-3-8-0 @ 200 MHz
SPD registers
00 80 08 07 0D 0A 02 40 00 04 50 70 00 82 08 00 01
10 0E 04 1C 01 02 20 C0 60 70 75 75 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 37 46 30 28 50 00 01
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 81
40 2C FF FF FF FF FF FF FF 01 31 36 56 44 44 54 36
50 34 36 34 41 47 2D 34 30 42 43 34 04 00 04 06 1A
60 51 B1 D6 00 00 00 00 00 00 00 00 00 00 00 00 00
80 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
DIMM # 2
SMBus address 0x52
Memory type DDR
Manufacturer (ID) (004C454741435900)
Size 512 MBytes
Part number 88F5HDL0-1UDG
Serial number FFFFFFFF
Manufacturing date Week 255/Year 255
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
XMP no
SPD registers
00 80 08 07 0D 0A 02 40 00 04 50 50 00 82 08 00 01
10 0E 04 1C 01 02 20 C0 60 50 75 50 3C 28 3C 28 40
20 60 60 40 40 00 00 00 00 00 37 41 28 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 11 0E
40 00 4C 45 47 41 43 59 00 FF 38 38 46 35 48 44 4C
50 30 2D 31 55 44 47 00 00 00 00 00 01 00 FF FF FF
60 FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Mainboard Model D865GVHZ (0x00000226 - 0x009ED2C4)
LPCIO
LPCIO Vendor SMSC
LPCIO Vendor ID 0x55
LPCIO Chip ID 0x14
Config Mode I/O address 0x2E
Config Mode LDN 0x8
Config Mode registers
00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 14 04 01 00 44 00 2E 00 03 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Hardware Monitors
Hardware monitor Analog Device ADM1027
Voltage 0 1.48 Volts [0x72] (+1.5V)
Voltage 1 1.35 Volts [0x73] (CPU VCORE)
Voltage 2 3.28 Volts [0xBF] (ATX +3.3V)
Voltage 3 4.86 Volts [0xBB] (ATX +5V)
Voltage 4 11.92 Volts [0xBE] (ATX +12V)
Temperature 0 52°C (125°F) [0x34] (CPU)
Temperature 1 39°C (102°F) [0x27] (AUX)
Temperature 2 45°C (112°F) [0x2D] (System)
Fan 0 1058 RPM [0x9F8] (FANIN0)
Register space SMBus, base address = 0x0D800
SMBus request channel 0x0, address 0x2E
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 72 71 BF BC BF 36 28 2D 53 13 FF FF FF FF 3E 0A
30 51 FF 76 00 00 00 00 00 00 00 00 00 00 27 41 60
40 07 00 00 13 00 FF 00 FF 00 FF 00 FF 00 FF 81 7F
50 81 7F 81 7F FF FF FF FF FF FF FF FF 02 A2 02 94
60 74 74 A9 00 33 66 4C 32 2D 1E 46 37 41 45 80 00
70 00 00 00 00 00 00 32 A6 F0 00 00 55 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 72 71 BE BC BE 36 28 2D 59 0B FF FF FF FF F5 09
30 53 FF 86 00 00 00 00 00 00 00 00 00 00 27 41 60
70 00 00 00 00 00 00 0E 95 F0 00 00 55 00 00 00 00
Hardware monitor NVIDIA GeForce 6200
Temperature 0 59°C (138°F) (GPU Core)
PCI Device
Description Host Bridge
Location bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2570
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF4000000
Subvendor ID 0x8086
Subsystem ID 0x2570
Int. Line 0x00
Int. Pin 0x00
PCI capability
Caps class Vendor Dependant
Caps offset 0xE4
PCI registers
00 86 80 70 25 06 01 90 20 02 00 00 06 00 00 00 00
10 08 00 00 F4 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 86 80 70 25
30 00 00 00 00 E4 00 00 00 00 00 00 00 00 00 00 00
50 00 00 42 00 40 80 1C 00 00 00 00 00 00 00 00 00
60 08 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 10 11 11 00 00 33 33 00 00 00 00 00 00 1A 38 00
A0 02 00 30 00 17 42 00 1F 00 00 00 00 00 00 00 00
B0 00 00 00 00 30 00 00 00 00 00 00 00 10 10 00 00
C0 00 00 00 00 00 3F 0D 04 00 00 00 00 00 00 00 00
D0 02 28 04 0E 0B 0D 00 00 00 00 00 00 00 00 40 01
E0 00 00 00 00 09 00 06 11 00 02 00 00 00 00 00 00
F0 00 00 00 00 02 00 00 00 68 0F 03 00 00 00 00 00
Description Display Controller
Location bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2572
Revision ID 0x02
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xF8000000
Address 1 (memory) 0xFFF80000
Address 2 (port) 0x0000FFF8
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x00
Int. Pin 0x01
PCI capability
Caps class Power Management
Caps offset 0xD0
Caps version 1.0
PCI registers
00 86 80 72 25 00 00 90 00 02 00 80 03 00 00 00 00
10 08 00 00 F8 00 00 F8 FF F9 FF 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 D0 00 00 00 00 00 00 00 00 01 00 00
40 00 00 00 00 E0 23 E0 11 00 00 00 00 00 00 00 00
50 00 00 42 00 00 00 00 00 00 00 00 00 00 00 00 00
60 08 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 01 00 00 00 00 00 01 02 FF 00 00 00 71 62 50 20
B0 30 08 04 00 08 04 41 00 00 00 00 00 00 00 00 00
D0 01 00 21 00 03 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 09 00 06 11 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 68 0F 03 00 00 00 00 00
Description USB Controller (UHCI)
Location bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x24D2
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 4 (port) 0x0000C800
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x10
Int. Pin 0x01
PCI registers
00 86 80 D2 24 05 00 80 02 02 00 03 0C 00 00 80 00
20 01 C8 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 10 01 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 27 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 66 0F 04 00 00 00 00 00
Location bus 0 (0x00), device 29 (0x1D), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x24D4
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000CC00
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x13
Int. Pin 0x02
PCI registers
00 86 80 D4 24 05 00 80 02 02 00 03 0C 00 00 00 00
20 01 CC 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
Location bus 0 (0x00), device 29 (0x1D), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x24D7
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D000
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x12
Int. Pin 0x03
PCI registers
00 86 80 D7 24 05 00 80 02 02 00 03 0C 00 00 00 00
20 01 D0 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
Location bus 0 (0x00), device 29 (0x1D), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x24DE
Revision ID 0x02
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D400
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x10
Int. Pin 0x01
PCI registers
00 86 80 DE 24 05 00 80 02 02 00 03 0C 00 00 00 00
20 01 D4 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
Description USB 2.0 Controller (EHCI)
Location bus 0 (0x00), device 29 (0x1D), function 7 (0x07)
Common header
Vendor ID 0x8086
Model ID 0x24DD
Revision ID 0x02
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFEBFFC00
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x17
Int. Pin 0x04
PCI capability
Caps offset 0x50
Caps version 1.1
PCI capability
Caps class Debug Port
Caps offset 0x58
PCI registers
00 86 80 DD 24 06 01 90 02 02 20 03 0C 00 00 00 00
10 00 FC BF FE 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 50 00 00 00 00 00 00 00 17 04 00 00
50 01 58 C2 C9 00 00 00 00 0A 00 A0 20 00 00 00 00
60 20 20 00 00 00 00 00 00 01 00 00 00 00 00 00 C0
70 00 00 DF 3F 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 FF FF 00 00 00 00 00 00
F0 00 80 00 00 88 83 40 00 66 0F 04 00 06 14 00 00
Description PCI to PCI Bridge
Location bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x244E
Revision ID 0xC2
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 4E 24 07 01 80 00 C2 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 20 B0 B0 80 22
20 90 FA 90 FE 80 C2 70 E2 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 02
40 02 28 30 76 00 00 00 00 00 00 00 00 00 00 00 00
50 02 64 73 00 00 00 00 00 50 01 34 00 00 00 00 00
70 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 C1 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 01 00 02 00 00 00 C0 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 66 0F 04 00 00 00 4D 37
Description PCI to ISA Bridge
Location bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x24D0
Revision ID 0x02
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 D0 24 0F 01 80 02 02 00 01 06 00 00 80 00
40 01 04 00 00 10 00 00 00 00 00 00 00 00 00 02 00
50 00 00 00 00 00 00 00 00 01 05 00 00 10 00 00 00
60 8C 89 8A 83 D0 00 00 00 87 8B 80 85 00 00 00 00
90 FF FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 20 02 00 00 30 00 00 00 0D 00 00 00 00 03 01 00
B0 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
D0 86 21 00 00 00 0F 00 00 04 00 00 00 00 00 00 00
E0 10 00 00 80 81 06 0F 14 33 22 11 00 00 00 67 45
F0 00 00 60 00 04 00 00 00 66 0F 04 3E 00 00 00 02
Description IDE Controller
Location bus 0 (0x00), device 31 (0x1F), function 1 (0x01)
Common header
Vendor ID 0x8086
Model ID 0x24DB
Revision ID 0x02
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000FFA0
Address 5 (memory) 0xFFEFFC00
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0xFF
Int. Pin 0x01
PCI registers
00 86 80 DB 24 07 00 88 02 02 8A 01 01 00 00 00 00
10 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
20 A1 FF 00 00 00 FC EF FF 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 01 00 00
40 00 80 03 A3 00 00 00 00 04 00 00 02 00 00 00 00
50 00 00 00 00 44 00 00 00 00 00 00 00 00 00 00 00
60 08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00
Location bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
Vendor ID 0x8086
Model ID 0x24D1
Revision ID 0x02
PI 0x8F
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (port) 0x0000EC00
Address 1 (port) 0x0000E800
Address 2 (port) 0x0000E400
Address 3 (port) 0x0000E000
Address 4 (port) 0x0000DC00
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x12
Int. Pin 0x01
PCI registers
00 86 80 D1 24 05 00 A0 02 02 8F 01 01 00 00 00 00
10 01 EC 00 00 01 E8 00 00 01 E4 00 00 01 E0 00 00
20 01 DC 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 12 01 00 00
40 07 A3 00 80 00 00 00 00 01 00 01 00 00 00 00 00
50 00 00 00 00 11 10 00 00 00 00 00 00 00 00 00 00
70 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
80 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 13 00 00 20 00 00 00 00 00 00 00 00 00 00
Description SMBus Controller
Location bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
Vendor ID 0x8086
Model ID 0x24D3
Revision ID 0x02
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000D800
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x09
Int. Pin 0x02
PCI registers
00 86 80 D3 24 01 00 80 02 02 00 05 0C 00 00 00 00
20 01 D8 00 00 00 00 00 00 00 00 00 00 7B 10 43 40
30 00 00 00 00 00 00 00 00 00 00 00 00 09 02 00 00
40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Description VGA Controller
Location bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0221
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x00
Latency 0xF8
Header 0x00
PCI header
Address 0 (memory) 0xFD000000
Address 1 (memory) 0xD0000000
Address 2 (memory) 0xFC000000
Subvendor ID 0x3842
Subsystem ID 0xB399
Int. Line 0x15
Int. Pin 0x01
PCI capability
Caps offset 0x60
Caps version 1.1
PCI registers
00 DE 10 21 02 07 01 B0 02 A1 00 00 03 00 F8 00 00
10 00 00 00 FD 08 00 00 D0 00 00 00 FC 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 42 38 99 B3
30 00 00 00 00 60 00 00 00 00 00 00 00 15 01 05 01
40 42 38 99 B3 02 00 30 00 03 00 00 1F 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 0F 00 00 00
60 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 01 04 40 C1 00 00 00 00
Description Video device
Location bus 1 (0x01), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x11DE
Model ID 0x6057
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x04
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE9DE000
Subvendor ID 0x1031
Subsystem ID 0x7EFE
Int. Line 0x11
Int. Pin 0x01
PCI registers
00 DE 11 57 60 06 00 00 00 02 00 00 04 00 20 00 00
10 00 E0 9D FE 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 31 10 FE 7E
30 00 00 00 00 00 00 00 00 00 00 00 00 11 01 02 10
Description Ethernet Controller
Location bus 1 (0x01), device 8 (0x08), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x1050
Revision ID 0x02
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x20
Header 0x00
PCI header
Address 0 (memory) 0xFE9DF000
Address 1 (port) 0x0000BC00
Subvendor ID 0x107B
Subsystem ID 0x4043
Int. Line 0x14
Int. Pin 0x01
PCI capability
Caps offset 0xDC
Caps version 1.1
PCI registers
00 86 80 50 10 17 01 90 02 02 00 00 02 10 20 00 00
10 00 F0 9D FE 01 BC 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 DC 00 00 00 00 00 00 00 14 01 08 38
D0 00 00 00 00 00 00 00 00 00 00 00 00 01 00 22 FE
E0 00 40 00 3A 00 00 00 00 00 00 00 00 00 00 00 00
Description System Device
Location bus 0 (0x00), device 6 (0x06), function 0 (0x00)
Common header
Vendor ID 0x8086
Model ID 0x2576
Revision ID 0x02
PI 0x00
SubClass 0x80
BaseClass 0x08
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xFECF0000
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
PCI registers
00 86 80 76 25 02 00 80 00 02 00 80 08 00 00 00 00
10 00 00 CF FE 00 00 00 00 00 00 00 00 00 00 00 00
40 40 65 00 04 00 00 00 00 04 00 00 00 00 00 00 00
50 01 00 8F 00 00 00 00 00 00 00 00 00 00 00 00 00
70 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 55 05 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 20 08 00
B0 00 00 00 00 F0 43 FC 7D 01 00 00 00 09 00 00 00
C0 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF 3F
E0 01 00 00 00 00 00 01 02 FF 0E 00 00 00 00 04 00
F0 00 0C 02 00 00 00 00 00 68 0F 03 00 74 F8 00 00
DMI
DMI BIOS
vendor Intel Corp.
version BF86510A.15A.0085.P20.0412152353
date 12/15/2004
DMI System Information
manufacturer GATEWAY
product T3882
version unknown
serial unknown
UUID 2D74D394-B3A311D9-AE48000E-A6292A1D
DMI Baseboard
vendor Intel Corporation
model D865GVHZ
revision AAC93540-101
serial FCHZ51800941
DMI System Enclosure
manufacturer unknown
chassis type 2X
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Celeron(R) CPU processor
clock speed 2800.0 MHz
FSB speed 133.0 MHz
multiplier 21.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024 MBytes
DMI Memory Module
designation DIMM1
size 512 MBytes (double bank)
DMI Memory Module
designation DIMM2
DMI Memory Module
designation DIMM3
DMI Memory Module
designation DIMM4
DMI Port Connector
designation J1A1 (internal)
designation PS2Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation J2A1 (internal)
designation COM 1 (external)
port type Serial Port 16550A
connector DB-9 female
DMI Port Connector
designation J4A2 (internal)
designation LPT1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation JA5A1 (internal)
designation USB (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
port type USB
DMI Port Connector
designation J4A1 (internal)
designation VIDEO (external)
port type Video Port
connector DB-15 male
DMI Port Connector
designation J2A2 (internal)
port type USB
DMI Port Connector
port type USB
DMI Port Connector
designation RJ-45 Type (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation J6A1 (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (external)
DMI Port Connector
designation Audio Line Out (external)
DMI Port Connector
designation J5C1 - +12V (internal)
DMI Port Connector
designation J4H1 - FDD (internal)
connector On Board Floppy
DMI Port Connector
designation J6H2 - PRI IDE (internal)
connector On Board IDE
DMI Port Connector
designation J6H1 - SEC IDE (internal)
DMI Port Connector
designation J8B1 - CDIN (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation J6B1 - AUX IN (internal)
DMI Port Connector
designation J9G1 - FRONT PANEL HDR (internal)
DMI Port Connector
designation J2F1 - CPU FAN (internal)
DMI Port Connector
designation J9H3 - FNT PNL (internal)
DMI Port Connector
designation J9H3 - FRONT CHASSIS FAN (internal)
DMI Port Connector
designation J1B1 - REAR CHASSIS FAN (internal)
DMI Port Connector
designation J9H2 - BIOS CONFIG (internal)
DMI Port Connector
designation J8A1 - FP AUDIO (internal)
connector Proprietary
DMI Port Connector
designation J9F1 - FRONT PANEL USB (internal)
DMI Port Connector
designation J2H1 - PS (internal)
DMI Port Connector
designation J8H3 - CH INTR (internal)
DMI Port Connector
designation J8H2 - SCSI (internal)
DMI Extension Slot
designation J6C1
type AGP 4x
width 32 bits
populated yes
DMI Extension Slot
designation J7B1
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation J8B2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation J9B1
type PCI
width 32 bits
populated yes
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 4096 MBytes
max# of devices 4
DMI Memory Device
designation J6G1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation J6G2
format DIMM
type DDR
total width 64 bits
data width 64 bits
DMI Memory Device
designation J6H1
format DIMM
type DDR
total width 64 bits
data width 64 bits
size 512 MBytes
DMI Memory Device
designation J6H2
format DIMM
type DDR
total width 64 bits
data width 64 bits
Graphics
Number of adapters 1
Graphic APIs
API NVIDIA NVAPI
API NVIDIA I/O
Display Adapters
Display adapter 0
Manuf. API index 0
Display name \\.\DISPLAY1
Name NVIDIA GeForce 6200
Revision A1
Codename NV44
Technology 0.11 um
Memory size 256 MB
Memory type DDR
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x3842)
Model ID 0x221 (0xB399)
Performance Level 3D Applications
Core clock 300.0 MHz
Memory clock 532.0 MHz
Software
Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
DirectX Version 9.0c
PostPosted: Mon Sep 21, 2009 3:57 am
Replacing OEM bioses with genuine Intel retail ones is no 100% surefire match. In this case it seems possible but you need to use the floppy drive. Yes, I know it is old but for the recovery method it is the best option. 2nd posting here explains what to do. ymmv...
http://e4allupgraders.info/dir1/motherb ... sers.shtml
Have fun.
PostPosted: Mon Sep 21, 2009 10:03 am
Tried the instructions on the intel site for emergency bios restore...(cd version and it didn't work). Tried to create a floppy disk directly from the intel dos bios setup, didn't work.
Finally, what worked...(after a lot of trial and error)
I created a floppy of the intel bios dos version, burned it to a cd (floppy emulation)...booted with the cd...formatted a real floppy under the freedos of the intel boot cd (intel bios must like the freedos format a bit better?). Copied the .BIO file from the CD to the floppy... Removed the jumper...ran the emergency bios restore using just the floppy...4 repeating pc beeps in low to high tone order... restarted...immediately entered bios, DISABLED BUILT IN NIC (otherwise will lock)...if the nic is not disabled the system will not restart a second time! So with future intel bios updates I will have to remember to disable the onboard NIC IMMEDIATELY...If the system does try to boot with the NIC not disabled, you have to shut the system down completely, remove the battery, insert the battery, boot and disable the NIC...
I already had a higher end NIC, VIDEO, and SOUND, so I ended up disabling most of the onboard built in's. There are a ton of options that pop up in the bios after the update. And it will allow me to update my processor as well. Finally, I can tell emachines to suck off with their antique driver options (that never included a bios update)!
PostPosted: Mon Sep 21, 2009 10:40 am
a side effect of the upgrade is that the fan speeds are stuck at max for the processor and case. I found a forum somewhere online that said it had to do with the fan connections are switched differently in the different bios versions. I'm attempting to utilize a utility like speedfan, motherboard monitor or Core Temp to figure out if i have to buy super quite fans or not...any other suggestions?
PostPosted: Mon Sep 21, 2009 11:27 am
Speedfan and the like are not likely to work, as they don't support the proprietary sensors built into OEM boards, only the dead-stock Winbond chips. You can certainly try, but I really don't think they'll work at all at best, or lock up the system completely at worst. Just curious, why do you want to use a BIOS that doesn't work properly?
Faster than the speed of snot
PostPosted: Mon Sep 21, 2009 2:16 pm
More options in the bios settings. To what extent they actually can be used remains to be seen though.
PostPosted: Mon Sep 21, 2009 4:06 pm
the ratio can be adjusted, the processor can be upgraded, the system runs quite a bit faster, the onboard video and the additional video board can be used simultaniously, onboard sound and additional sound board can be run simultaniously, larger hard drives are supposedly supported, the onboard video resolution is now capable of about 4 or 5 times the resolution, the bios is now capable of being updated with retail intel updates (as apposed to being stuck with a 2004 bios)...
all of these benifits and my only problem at this point with it is the fan runs full speed (quite a few options to get around it) and i had to disable the slower onboard nic.
PostPosted: Wed Sep 23, 2009 6:31 am
fans can't be adjusted (run full speed) because they are all only 3 pin...I have a few voltage regulators coming from newegg that will allow me to dial down the fan speeds electrically. The stock processor fan seems pretty nice...it runs at about 4600 RPM at full speed and keeps the processor at 47 degrees (cell D precott can run up to 67)...
PostPosted: Sun Jun 01, 2014 9:40 am
hey im trying to ugrade my cpu as well can u help me please, I TOO HAVE AN E-MACHINE(w-3611) WITH a 2006 bios just wanted to know if u can help me with updating my intel mobo to the latest bios
THANKS
RUBEN
PostPosted: Mon Jun 02, 2014 7:08 am
re: 1033ruben posting..
Do you have the full BIOS string for that system? First video screen, lower left corner, there should be a string of characters. That is the positive ID of the motherboard, BIOS and version/inception date. Post that here for a better chance as to possibly finding a later BIOS update.
Some of those older designs may accept newer CPU types.. but if the controller chips don't have the range for higher FSB speed or CPU type, not a fair chance of success.
