It is currently Fri Jan 18, 2019 1:45 am
PostPosted: Fri Jun 22, 2007 4:41 am
Hey all,
Yet another HP no marking serial numbers nothing apart from in between the pci slots is
Maverick / Silverado
Any ideas?
PostPosted: Fri Jun 22, 2007 10:08 am
email a picture to me please so we have at least an idea of what we're dealing with. any info (socket, number of slots) might help.
PostPosted: Fri Jun 22, 2007 11:48 am
Can U post any numbers/letters pinted on the chips? sometimes even the model/number is printed there. numbers, decriptions (how many ports of each type) and pics make the indentification easier and more efficient
 Post subject: Sandra Results
PostPosted: Sat Jun 23, 2007 3:18 pm
SiSoftware Sandra
System
Manufacturer : Hewlett-Packard
Model : HP Compaq dc7700p Convertible Minitower
Family : 103C_53307F
Serial Number : CZC6415492
SKU Number : RN306ES#ABZ
System Chassis
Type : Mini Tower
Can be locked : No
Asset Tag : CZC6415492
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Mainboard
Platform Compliance : Intel vPro
MP Support : 2 Processor(s)
MPS Version : 1.40
Model : 0A58h
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 4GB
Bank 1 - XMM1 : Micron 8HTF6464AY-667D7 43FD15D2 DIMM Synchronous DDR2-SDRAM 512MB/64 @ 667Mt/s
Bank 2 - XMM2 : Micron 16HTF12864AY-667D4 C1B614D5 DIMM Synchronous DDR2-SDRAM 1GB/64 @ 667Mt/s
Bank 3 - XMM3 : Micron 8HTF6464AY-667D7 F9FC15D2 DIMM Synchronous DDR2-SDRAM 512MB/64 @ 667Mt/s
Bank 4 - XMM4 : Micron 16HTF12864AY-667D4 8DB614D5 DIMM Synchronous DDR2-SDRAM 1GB/64 @ 667Mt/s
FLASH Memory Controller
Number of Memory Slots : 1
Maximum Installable Memory : 1MB
Bank 5 - SYSTEM ROM : Chip Non-Volatile FLASH 1MB/2
Chipset 1
Model : Hewlett-Packard Company Q963/Q965 Memory Controller Hub
Bus(es) : X-Bus PCI PCIe IMB USB i2c/SMBus
Maximum FSB Speed / Max Memory Speed : 4x 333MHz / 4x 400MHz
Width : 64-bit
SMP - MP Capability : No
IO Queue Depth : 12 request(s)
Chipset 1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
Number of Ports : 4
In/Out Width : 4-bit / 4-bit
Multiplier : 3/1x
Speed : 1x 100MHz (100MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Bank 2 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Bank 3 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Bank 4 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Bank 6 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Bank 7 : 512MB DDR2-SDRAM 5.0-5-5-15 (tCL-tRCD-tRP-tRAS) CR1
Shared Memory : 8MB
Channels : 2
Multiplier : 5/4x
Width : 64-bit
Memory Controller in Processor : No
Performance Acceleration Technology : No
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
APIC 1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module 1
Manufacturer : Micron
Model : 8HTF6464AY-667D7
Serial Number : D215FD43
Type : 512MB DIMM DDR2-SDRAM
Technology : 8x(64Mx8)
Speed : PC2-5300U DDR2-333
Standard Timings : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Version : 1.2
Date of Manufacture : 08 January 2007
Memory DC Line : 1.8V
Set Timing @ 333MHz : 5.0-5-5-15 (tCL-tRCD-tRP-tRAS)
Set Timing @ 267MHz : 4.0-4-4-12 (tCL-tRCD-tRP-tRAS)
Set Timing @ 200MHz : 3.0-3-3-9 (tCL-tRCD-tRP-tRAS)
Memory Module 2
Model : 16HTF12864AY-667D4
Serial Number : D514B6C1
Type : 1GB DIMM DDR2-SDRAM
Technology : 16x(64Mx8)
Version : 1.2
Date of Manufacture : 07 May 2007
Memory Module 3
Serial Number : D215FCF9
Version : 1.2
Memory Module 4
Serial Number : D514B68D
Version : 1.2
Environment Monitor 1
Model : Intel Core CPU [P1, C2, M0]
Version : 15.06
Mainboard Specific Support : No
Temperature Sensor(s)
CPU1 Temperature : 58.0°C / 136.4°F td
PCI Bus(es) on Hub 1
Version : 2.30
Number of Bridges : 2
PCI Bus 0 : PCI (1/1x PCIClk)
PCI Bus 7 : PCI (1/1x PCIClk)
PCI Bus 32 : PCIe (3/1x PCIClk)
Number of PCIe Lanes : 1
LPC Hub Controller 1
Model : Hewlett-Packard Company 82801HO (ICH8DO) LPC Interface Controller
ACPI Power Management Enabled : Yes
Advanced TCO Mode Support : Yes
Advanced TCO Mode Enabled : No
High Precision Timer Enabled : Yes
Number of Precision Timers : 3
System Timer : 14MHz
Delayed Transaction Enabled : Yes
LPC Hub Controller 2
Model : Intel Corporation 82801H (ICH8 Family) SMBus Controller
LPC Legacy Controller 1
Type : SMSC LPC v1
Version : 85.02
Number of Enabled Devices : 6
USB Controller 1
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB UHCI #4
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB UHCI #5
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 3
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB2 EHCI #2
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 4
Companion Controllers : 2
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
USB Controller 4
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB UHCI #1
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 5
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB UHCI #2
Version : 1.10
Interface : UHCI
Channels : 2
Speed : 48MHz
USB Controller 6
Model : Hewlett-Packard Company 82801H (ICH8 Family) USB2 EHCI #1
Version : 2.00
Interface : EHCI
Channels : 4
System SMBus Controller 1
Model : Intel 801xx/63xx SMBus
Version : 0.02
Specification : 2.00
Advanced TCO Mode Enabled : Yes
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
PCI1 (1h) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available
PCI2 (2h) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available (Hewlett-Packard Company Q963/Q965 Integrated Graphics Controller)
PCI EXPRESS x1 SLOT/PCIEx1 (1h) : PCIe x2 +3.3V PME i2c/SMBus Full-Length Available
PCI EXPRESS x16 SLOT/PCIEx16 (1h) : PCIe x64 +3.3V PME i2c/SMBus Full-Length Available
Port Connector(s)
SATA0 : None
SATA1 : None
SATA2 : None
SATA3 : None
SERIAL A - COM A : Serial Port 16550A / DB-9 pin male
SERIAL B : Serial Port 16550A / DB-9 pin male
PARALLEL : Parallel Port ECP/EPP / DB-25 pin female
USB 1 : USB / USB
USB 2 : USB / USB
USB 3 : USB / USB
USB 4 : USB / USB
USB 5 : USB / USB
USB 6 : USB / USB
FRONT USB - USB 7 : USB / USB
FRONT USB - USB 8 : USB / USB
KEYBOARD : Keyboard / PS/2
MOUSE : Mouse / PS/2
REAR MIC : Audio / Mini-DIN
REAR LINE IN : Audio / Mini-DIN
VIDEO : Video / DB-15 pin female
REAR HEADPHONE/LINEOUT : Audio / Mini-DIN
RJ45 : Network / RJ-45
CPU FAN : None
FLOPPY : Floppy Disk
FRNT AUD - FRONT HEADPHONE/LINEOUT & MIC : Audio / Mini-DIN
CHASSIS FAN : None
SPEAKER (SPKR) : None
PASSWORD CLEAR (PSWD) : None
HOOD SENSE (HSENSE) : None
HOOD LOCK (HLCK) : None
POWER BUTTON : None
PostPosted: Thu Oct 20, 2011 6:08 pm
MAVERICK/SILVERADO
Rev: 0B
gonna take a gamble on this and say dual codename (have seen a few other boards with a similar patern)
Unknown retail equivilant still though:
http://www.aliexpress.com/product-gs/46 ... alers.html
Compaq-Fu Master
PostPosted: Sun May 11, 2014 5:25 am
It is an OEM Lite-On PR190:
http://www.ctechinfo.net/motherboards/l ... silver.php
Compaq-Fu Master
PostPosted: Thu Jun 22, 2017 3:08 am
Hello! First of all, want to say BIG,BIG,BIG thanks for this outstanding prog!!!
Very handy and usefull!!!
sisoft-sandra-lite
I downloaded the latest version, to view the hardware data and themes, now I plan to monitor the CPU usage of the software.
Edit: took out active URL link for insecure site.
...Karlsweldt.
PostPosted: Thu Jun 22, 2017 8:50 am
Re posting by Samuel1:
While that Sisoft Sandra program is worthy, best to obtain it from a parent site.
Other sites may infect the data with malware!
http://www.sisoftware.net/
