It is currently Mon Jan 21, 2019 2:13 pm
 Post subject: Cases Solved/verified
PostPosted: Fri May 31, 2002 8:50 pm
Unsolved Mobocop Cases - still listed as "unsolved"
Case #1 PC Chips M535 or M538 (Solved)
Case 45 PC Chips M710 (Solved)
Toby
PostPosted: Fri May 31, 2002 9:02 pm
You can't list a case as solved by quoting its one or the other...does not work that way. When you can narrow down the board directly, then you have it. Otherwise it will remain unsolved.
PostPosted: Fri May 31, 2002 9:09 pm
Sorry Hardware Junkie, the first one has two matches - Please post the pics of the boards for a comparison.........The second ID was a definate match - www.plasma-online.come listed that exact BIOS String as the PC Chips M710....
I do not know who originall post the MoboCop Case #1 but the info that I found was a match to both.
Toby
PostPosted: Fri May 31, 2002 9:42 pm
Oh you think those are the only 2 boards do you? :D
Check this one out:
http://www.plasma-online.de/english/ide ... urone.html
M520, M530...etc...
PostPosted: Fri May 31, 2002 10:02 pm
OK!!!!!!!!!!!!!!!!!!!!!!!SO I am a freakin IDIOT!!!!!!!!!!!!!!!!!!!!!!!! I got both wrong!!! :oops: Case #45 Bios doesn't even match a M715 according to plasma-online the string for a M715 start with 51 NOT 61
Toby - AKA "the blooming IDIOT"
PostPosted: Fri May 31, 2002 10:08 pm
Don't worry do0d, you'll get there. I have made a few big mistakes along the road to MoboFu Master...
Essentually case #45 should look like this:
61-0701-007170-001101111-0715-M717-1440L000-H
OR
61-1027-001169-00111111-071595-440LX-1440L000-H
But the case 45 is a match with the M715. I editted the ROM file and it does show the 000715 customer code. So I have closed the case.
PostPosted: Fri May 31, 2002 10:18 pm
OR
000715 is not in the database. So its a bit suspicious. We would need a description to solve this one.
That second string matches this (MS-6122 v1.2) found through Plasma-online via a google search.
Toby
PostPosted: Fri May 31, 2002 10:19 pm
The customer code does not match, and 440LX is missing aswell. I have already confirmed it is the M715.
Case closed. 8)
PostPosted: Fri May 31, 2002 10:57 pm
What I try to do is getting the confirmation out of more than one factor, e.g a Delhi board from an eMachine is the TriGem Delhi III.
The serial number on newer Intel boards has the first two characters of the model name (not quite for the D8nnXX series (e.g D845HV), there it's the first two after D8nn) hidden in it. (Try and figure out that one out, Toby).
If a case has more than one possible match, it can't be solved without the original poster confirming or adding more info to the case. A sole 2A59XXXX string isn't always enough (FIC has the same string for six different boards, it's the rest of the string that matters as well).
