It is currently Fri Sep 18, 2020 9:37 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page 1, 2  Next
PostPosted: Mon Nov 20, 2006 9:06 pm
05/11/2000-693a-686-6a6lgl1fc-00
on the board have write this: 6va693a rev:3.0
this board have:
- 2 x isa slot
- 4 x pci slot
- 1 x agp slot
- 1 x amr slot
- 3 x dimm slot
- slot 1 cpu port
hope will get info for this board as soon as posible. thanks for help :-)
PostPosted: Mon Nov 20, 2006 9:29 pm
It's a Lucky Star socket 370 motherboard.
A little chlorine for the gene pool please.
PostPosted: Mon Nov 20, 2006 9:33 pm
i think that is slot 1 mobo because just have slot 1..dont have socket370
PostPosted: Mon Nov 20, 2006 9:58 pm
One site says 370, the other says slot 1...bottom line is it is a Lucky Star mobo.
Google is your friend.
PostPosted: Mon Nov 20, 2006 11:16 pm
Manual:
http://www.elhvb.com/mboards/luckystar/ ... Index.html
6va693a-v30.zip
More info:
http://web.tiscali.it/acorp/?http://web ... va693a.htm
PostPosted: Tue Nov 21, 2006 6:12 am
PostPosted: Sat Dec 23, 2006 3:16 am
how about drivers for this mb? can someone help me to find it. i already try to search it but not get it.
PostPosted: Sat Dec 23, 2006 4:42 am
chipset drivers:
http://www.viaarena.com/default.aspx?Pa ... CatID=1070
audio
http://www.viaarena.com/default.aspx?Pa ... bCatID=100
AC97 for the 686A southbridge.
You can also find drivers there for other OSes.
PostPosted: Sat Dec 23, 2006 12:37 pm
PostPosted: Tue May 22, 2007 9:37 am
04/05/2000-694x-686a-6a6ljtg9c-00
on the board have shown this word "g3s-apa+"
need drivers and manual for this board.
"..Tuhan..dosaku menggunung tinggi..tapi rahmatMu..melangit luas.."
