It is currently Mon Aug 20, 2018 9:25 pm
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Thu May 30, 2002 4:43 pm
:?: I need some help, please. The bios string is:
06/21/96 I430VX-2A59Ht5BC-00 it's Award Bios. The board has 4 ISA, 3 PCI, 4x72 pin simm, & 1x168 pin dimm. It's a socket 7 board, AT form factor. The thing that confuses me is that from what I could find the bios id's it as a Tyan board, yet on the back side of the board it says Elpina. I would like to find a manual for this board if possible. I need to know if it supports P200MMX. Any help would be appreciated, thanx. :?
PostPosted: Thu May 30, 2002 6:24 pm
Refer to this thread. It might help a little.
http://www.motherboards.org/forums/viewtopic.php?t=474&highlight=elpina
PostPosted: Thu May 30, 2002 6:38 pm
My dad used to have that board and i remember the hell i went through trying to figure out what it was....i don't think i ever figured it out, but i still have a copy of the manual. It will support a pentium 200, but the book doesn't say anything about mmx one way or the other. Its only 33 pages, maybe i can scan it and send you the images.
PostPosted: Thu May 30, 2002 6:46 pm
http://web.tiscali.it/acorp/?http://web ... number.htm
from what I can pull up on a google search its a PCchips M520 (inknown revision)
Will look further
Toby
PostPosted: Thu May 30, 2002 6:56 pm
You would be correct.
http://www.wimsbios.com/~ajzchips/
 Post subject: That looks like the one!
PostPosted: Thu May 30, 2002 7:06 pm
that looks like the right board. i hope that soon i'll be able to find this stuff on my own, and maybe help someone else out. thanks alot you guys, your the greatest! :D
PostPosted: Thu May 30, 2002 7:07 pm
hold a sec!!!!!!!!!there is an Elpina board with that matches!!!!!will post in a minute.
Toby
Elpina TS-M-8VOC - dont know where to find manual no luck with a google search!!!!!
PostPosted: Thu May 30, 2002 7:19 pm
Elpina is PC Chips..... :|
Edit TS-XX-XXXX motherboards are TopSearch (another PC Chips close), not Elpina
PostPosted: Thu May 30, 2002 7:37 pm
So apparently when you get a BIOS string that matches like 50 motherboards (i.e. Elpina, PCchips, Amptron..................) it automatically a PCchips board????
I know that Amtron is part of PCchips, but I did not know Elpina was too!!! 8O :oops:
Toby
PostPosted: Thu May 30, 2002 7:57 pm
Not a part of....is PC Chips...thier boards match. They are all the same.
