BIOS update for Jamicon KM533T
Postby evasive » Tue Jul 06, 2010 2:05 am
I forgot to point you to uniflash
http://www.rainbow-software.org/uniflash/
or flashrom
http://www.flashrom.org/Flashrom
Thank you very much for verifying it works with a disk larger than 64GB, what make/model is that disk?
Windows 98 does not natively support NTFS. You can reformat the drive with FAT32 if you want to do so. FAT32 is supported by both windows 98 and windows XP.
Postby enrico64 » Wed Jul 21, 2010 5:26 am
It is a Maxtor DiamondMax 20 with 80GB.
I did not convert to FAT32 because I had some hope to use the hard disk 'as it is' including the Win XP system. But meanwhile I gave up this (silly) idea.
Sorry for my late answer, I could not access the motherboards page for weeks, always got error 404.
enrico64
Postby evasive » Wed Jul 21, 2010 5:43 am
Windows XP usually needs to be reinstalled if you transfer a harddisk between 2 different systems. Unless you are lucky enough the installed mass storage controller drivers work with the controller the disk is connected to.
Thanks for reporting back though :-)
Previous
Users browsing this forum: Bing [Bot] and 2 guests
