Dell Motherboard
Postby kylerickards » Mon Oct 12, 2009 2:01 pm
That's exactly what I needed, thank you!! Is there anywhere for speaker to go or should I not connect that one?
Kyle
kylerickards
Postby evasive » Mon Oct 12, 2009 2:02 pm
That may be a seperate connector with 4 pins in a row.
It's possible you have an onboard buzzer thingy.
If neither, I'll check the connector on one of my D845xxx boards that seems to match these.
Postby kylerickards » Mon Oct 12, 2009 2:04 pm
Again, many thanks, the case I was working on had a speaker attached to front of it with wire going back to motherboard but I can't see anywhere for it to plug into. It was a very old case though...
Kyle
kylerickards
Front panel
Postby kylerickards » Fri Oct 16, 2009 6:25 am
Hi
On the new case I have got, I have leads for front USB, front audio and front speaker. Can I use these or just tie neatly?
Thanks
Kyle
kylerickards
Postby evasive » Fri Oct 16, 2009 1:41 pm
If there are headers for USB and audio on the board you may be able to use them. If not, tie them neatly.
Previous
Users browsing this forum: Google [Bot], Qwantify [Crawler] and 3 guests
