It is currently Mon Feb 18, 2019 6:31 am
PostPosted: Sun May 26, 2002 3:02 am
Hello to all,
I need your help to identify my Mainboard, wich has not yet an BIOS Chip. Now some details:
- Slot 1
- 1 AGB Slot
- 4 PCI Slots
- 2 ISA Slots
- 3 DIMM Sockets
- IDE Onboard
- Sound Onboard (Yamaha XG)
- ATX Formfactor and Powerconnector
- 2 USB connectors
- 2 * COM, 1 * LPT
- Sound-Connector (MIDI, In, Out, Mic)
- I think it is a BX Board with VIA VT82C596B Southbridge (it supports 100 MHz FSB max
- No Vendor or Model Printed on the Board
- Two Sticker on last ISA Slot:
S/N : M9909119895
C0942103260
- "Year 2000 Compiliant" "AGP" printed in the middle
- 3 Plugs for Cooler connect
- "M101 198" is printed on the Board, but I dont know what this means?
- 2 ITE Chips in front of the PSI Slots
- A smal red LED behind the ISA Slots at the Panel Connectors
If a Photo of the Board will help you to identify it, I can post one or send it to you, please tell me (my Camera has no Batteries in the moment).
Thank very much
Jens
PostPosted: Sun May 26, 2002 7:04 am
Check the top of the bios chip for a CT-xxx number and please reply with that number.
PostPosted: Sun May 26, 2002 7:09 am
M101 is usually present on Chaintech boards, not sure about a combo BX/VIA chipset board though. I think that you will find that the board is one or the other, either BX or VIA.
Here's some possibilities:-
Chaintech CT-6VTA3
http://www.chaintech.com.tw/PRODUCTI/mainboar/slot1/6VTA3.htm
Chaintech CT-6BTA
http://www.chaintech.com.tw/PRODUCTI/mainboar/slot1/6BTA.htm
Chaintech CT-6BTA2
http://www.chaintech.com.tw/PRODUCTI/mainboar/slot1/6BTA2.htm
A quick refresh tells me that evasive is onto the Chaintech connection as well. :lol:
Aussie
PostPosted: Sun May 26, 2002 7:30 am
Thanx a Lot, it is the Chaintech CT-6VTA3, my Problem is it has no BIOS Chip, does someone know wich one I need?
Thanx
Jens
PostPosted: Sun May 26, 2002 7:42 am
Winbond 29C020 (256Kb Biosfile)
Winbond 29C011/EE011(128KB Biosfile)
Chips from Atmel or SST should work .
PostPosted: Sun May 26, 2002 7:55 am
The CT-6VTA3 uses a 256Kb bios file.
http://www.chaintech.com.tw/ap/BIOS/model.asp?model=6VTA3&Submit=GO%21
Here's a couple of sites that may be able to help you with a new chip:-
http://www.flashbios.org/
http://www.badflash.com/
Aussie
