It is currently Sat Feb 23, 2019 5:07 am
PostPosted: Sun May 19, 2002 10:27 am
My USB doesn't work and I am trying to find a manual or maybe drivers that will fix this.
Here is all I find when searching for manufacturer of the motherboard.
The chipsets are labeled VIA VT82C586A and VT82C595
Thanks for any help,
Using bios wizard I found the following:
Generated by: BIOS Wizard 2.10
Date: May 19, 2002
Time: 13:28
PnP Version : BIOS currently supports latest version 1.0
PCI Version : BIOS currently supports latest version 2.1
PCI IRQ Routing Table : BIOS currently supports this feature
Enhanced Disk Drive
Specification : BIOS currently supports this feature
DMI Version : Current version is 2.0. The minimum DMI version is
2.1
ACPI Version : ACPI is not found
APM Version : BIOS currently supports latest version 1.2
Booting From CD-ROM : BIOS currently supports this feature
Supports ESCD : BIOS currently supports this feature
Can be Updated (flashed) : BIOS currently supports this feature
Can be Shadowed : BIOS currently supports this feature
BIOS Chip in Socket : BIOS currently supports this feature
Supports Selective Booting : BIOS doesn't support this feature
Supports LS-120 Booting : The testing of this feature is not supported by
the current DMI version
Supports ZIP Booting : The testing of this feature is not supported by
Supports Network Booting : The testing of this feature is not supported by
BIOS Manufacturer : American Megatrends
BIOS ID : 51-0606-000000-00111111-071595-VP2
BIOS Date : 07/15/95
BIOS OEM Signon :
BIOS ROM Size : 128K
Chipset : AMD 640 rev 3
Super I/O Chip : SMC 669 rev 2 found at port 3F0h
Searching google, I found this at http://computertech.server101.com/amibios.htm
51-0606-000000-00111111-071595-VP2-PA2011-T99-F: FIC Model: PA2011
and using the AMI wizard I got this:
AMIBIOS Motherboard Manufacturer Identification
Version 1.2 (02/07/2001) Copyright 2000 American Megatrends, Inc.
This file has recorded information useful in identifying the manufacturer
of this motherboard. The information is listed below:
An AMIBIOS ID String Was Detected:
| | | Chipset/BIOS Info
| | Manufacturer ID
| Version Information
Processor & BIOS ROM Information
The Manufacturer Code Detected (0000) Does Not Have A Database Entry.
The Following AMIBIOS Project Tag Was Found: _TG_PA2011-T99
PostPosted: Sun May 19, 2002 11:19 am
You can download a copy of your manual from here.
http://www.bigedtech.com/oldbigedtech/Download/Manuals/FIC/PA2011/fic_pa2011_users_manual_download.htm
Hope this is of some help.
Tau
Havnt got the hang of posting a decent link yet !
Tau.
"Learn from other people's mistakes, it's quicker."
PostPosted: Sun May 19, 2002 12:19 pm
Hit the URL button, copy/paste link after "[url]" then hit the URL button again.
PostPosted: Sun May 19, 2002 12:21 pm
To be sure it's a PA-2011 have a look onto the Board - the model number should be printed onto it usually between the PCI-Slots .
Maybe you have to look for the Revision number/PCB .
VIA-Chipset so use VIA drivers - 4in1 and USB driver from www.viaarena.com .
PostPosted: Sun May 19, 2002 1:44 pm
Thanks evasive
Hope you had a good weekend.
Tau.
:D :D :D
Tau.
PostPosted: Sun May 19, 2002 2:40 pm
I still am having a good one, Whit Monday is a holiday in this country 8)
Ah, the MBFM story, yes :D :D :D
PostPosted: Mon May 20, 2002 3:34 am
Full bios string should be 51-0606-000000-00111111-071595-VP2-PA2011-T99-F.
You can see the PA-2011 marking between the first and second PCI slot.
Aussie
 Post subject: thanks
PostPosted: Mon May 20, 2002 9:28 pm
:D Thanks for the quick reply, and the link to the manual.
