I am trying to find some info on a board that I have but am unable to figure out who the manufacturer is. The board has:
1 - agp slot
1 - amr slot?
5 - pci
1 - isa
3 - slots for pc100/pc133 memory
1 - socket A
1 - ps/2 keyboard
1 - ps/2 mouse
2 - IDE headers (one blue the other white)
1 - floppy header (black)
2 - usb ports
2 - 9 pin serial ports
1 - parallel port
onboard sound with midi connector above the sound connectors
There is only one sticker on the board that says KT133BX. There is a revision number on the top of the board that says 1.2(in lower left corner if the cpu is on top looking at it). There is a sticker on the ISA slot that says MI12KT133BX02 as well as an award bios sticker that says © 1998 PCI/PNP686 245212526. There is one visable VIA chip that has on it VT82C686B on it . There is another chip that is covered by a gold heatsink with the writing VT8363/VT8365 written below it on the board.
Need help identifying motherboard
Azza KT133BXThere is only one sticker on the board that says KT133BX.
Looking for info
[url=http://www.motherboards.org/folding/folding_faq.html][img]http://home.comcast.net/~boheemee/Sigs/GarfieldRct.JPG[/img][/url]
[url=http://valid.x86-secret.com/show_oc.php?id=364528][img]http://valid.x86-secret.com/cache/banner/364528.png[/img][/url]
well, i can't seem to find a working link to info on this board......need some help here......is this board the same as the KT3-AV, they look to be the same.....
- Brown Belt
thanks inteljunky, completely forgot about the archives...duh
- evasive
- Mobo-fu Master
- Contact:
at the moment there's a copy here:
http://mobokive.dyndns.org/Uploads/azza ... TX-E2B.PDF
most likely it will end up in the archive.
