It is currently Tue Sep 25, 2018 11:48 pm
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 29, 2014 9:50 am
Thanks for the info..
Compaq-Fu Master
PostPosted: Mon Dec 29, 2014 10:15 am
PS: If someone need it, I can get the pinout for the front USB ports, just need 20 minutes and a batery for my multimeter :P
PostPosted: Mon Dec 29, 2014 10:50 am
If/when you have time the info would be gladly appreciated.
Compaq-Fu Master
PostPosted: Mon Dec 29, 2014 5:40 pm
USB pinouts should be standard. But the wire color may not be. Most motherboard USB headers may have a 10-pin header, with one pin missing for a 'key'. The pin designations may be parallel, or inverse with some rogue manufacturers.
USB add-on ports, be they one or two, only need one shield ground. The other ground is a 'signal' ground for each.
http://www.allpinouts.org/index.php/USB ... Serial_Bus
http://pinouts.ru/Motherboard/usb_internal_pinout.shtml
