It is currently Tue Oct 23, 2018 6:53 pm
PostPosted: Sat Jun 22, 2002 3:54 pm
Intel board with PAL (platform architecture lab) on component side.
Ident PBA 668140-202 s/n N03240782
PCIset SB82441FX and 442FX
Solder side of board
PB 655573-002
PII-MP 94v-0
01-98 I
I have phoned Intel support and they have no record of this identification number in their database!
From the picture on their site it is NOT a PD440FX.
Board has 3xISA , 4xPCI, 4x 72pin Simm, 1x mothercard FRU76H 1815 D/C: 97515.
PostPosted: Sun Jun 23, 2002 2:32 am
I think you got yourself a server board. Will check my archives on this one...
One thing, is this a socket 8 (pentium Pro) or Slot 1 (Pentium II) board and how many processor can you fit?
PostPosted: Sun Jun 23, 2002 4:16 am
And I am going to need a picture for the layout. Getting absolutely zilch in my PBA/AA lists...
Check the mainboard top surface for any stickers and FRU numbers...
PostPosted: Sun Jun 23, 2002 5:33 am
Are you absolutely positive that the PD440FX doesn't match your board, the description certainly fits although I'm not quite sure what you mean by 1x mothercard.
Intel PD440FX.
Aussie
PostPosted: Sun Jun 23, 2002 9:18 am
Board is a Pentium II (only one processor).
Similar to PD440FX but battery in middle of board and configuration jumpers are orientated North-South and have designation J9D1 (not J9-C/A, C/B,C/C as for PD440FX)
The mothercard I refer to may not be the correct terminology but it is a card mounted near the processor slot which has INPUT 5VDC on top, made by VXI electronics.
The Bios chip is a PLLC next to the Serial Number its a TI 20R4-5CFN, so not much help there I'm afraid.
Thank you all for your replies so far.
PostPosted: Sun Jun 23, 2002 2:06 pm
his mothercard = voltage regulator module. At least that is what the IBM FRU part number points at.
I know there is a BN440FX (Boston) but I have zero information on that apart from the bios string...
PostPosted: Mon Apr 06, 2015 9:54 pm
Well, after all this time we found some info:
http://ps-2.kev009.com/pccbbs/intellist ... aw1bas.pdf
PostPosted: Sun May 10, 2015 10:17 pm
It's used in the Compaq Presario 4834, early models. Still looking for info from Compaq.
PostPosted: Tue May 12, 2015 5:01 pm
So it's worth mentioning? http://www.ctechinfo.net/forum/viewtopi ... =25&t=2426
Compaq-Fu Master
PostPosted: Tue May 12, 2015 9:21 pm
That I messed up again on part of getting the wrong IBM manual?
