It is currently Fri Sep 21, 2018 10:03 pm
PostPosted: Sun Jan 28, 2018 7:33 pm
The motherboard is a mini-itx type,(I assume) because of its small size. The processor is an Intel G840.2 slots of DDr3 ram. Can you please help me identify the model in order for me to download the manual and the specific drivers for this board. Thank you in advance.
https://imgur.com/a/dmRsE
PostPosted: Tue Jan 30, 2018 9:02 am
Can anyone help me please?
PostPosted: Tue Jan 30, 2018 9:08 am
SiSoftware Sandra
Computer
Chassis
Type : Desktop
Can be locked : No
Power Cord(s) : 1
Boot-up State : Safe
Power State : Safe
Thermal State : Safe
Security State : External Interface Locked-out
Mainboard
Manufacturer : 0001
Multi-Processor (MP) Support : No
Multi-Processing (MPS) Version : 1.40
Type : Mainboard
BIOS : 63-0100-000001-00101111-102010-Chipset
Mainboard Properties
Removable : No
Replaceable : Yes
Hot Swap : No
On-board Devices
Onboard IGD : Video Adapter (Enabled)
Onboard LAN : Ethernet Adapter (Enabled)
Onboard 1394 : Other (Enabled)
Chipset
Model : Intel Core (Sandy Bridge) DRAM Controller
OEM Device Name : Intel Core (Sandy Bridge) DRAM Controller
Revision : A10
Bus : CSI (Quick Path)
Front Side Bus Speed : 100MHz
Width : 20-bit / 20-bit
Maximum Bus Bandwidth : 400MB/s
Maximum Power : 3.900W
Chipset #1 Hub Interface
Type : DMI (Direct Media Interface)
Version : 1.00
No. Ports : 44
Logical/Chipset Memory Banks
Bank #2 : 4GB DIMM DDR3 9-9-9-24 4-33-10-5 1T
Shared Memory : 258MB
Maximum Memory : 32GB
Supported Memory Types : DIMM DDR3
Channels : 1
Width : 64-bit
Bank Interleave : 4-Way
Memory Bus Speed : 2x 667MHz (1.33GHz)
Maximum Speed : 1.33GHz
Multiplier : 20/3x
Integrated in Processor : Yes
Maximum Memory Bus Bandwidth : 10.42GB/s
APIC #1
Version : 2.00
Multiplier : 1/2x
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module
Manufacturer : Hynix (Hyundai)
Model : HMT351U6CFR8C-PB
Serial Number : 1266****
Type : 4GB DIMM DDR3
Technology : 8x(2048Mx8)
Speed : PC3-12800U DDR3-1600
Standard Timings : 11-11-11-29 5-40-13-6
Interface : 1.02
Version : 30.4E
Date of Manufacture : Tuesday, August 27, 2019
Memory DC Line : 1.500V
Temperature Sensor(s) : No
Timing @ 838MHz : 11-11-11-29 5-40-13-6
Timing @ 762MHz : 10-10-10-27 5-37-11-6
Timing @ 686MHz : 9-9-9-24 4-33-10-5
Timing @ 610MHz : 8-8-8-21 4-29-9-5
Timing @ 533MHz : 7-7-7-19 3-26-8-4
Timing @ 457MHz : 6-6-6-16 3-22-7-3
Sensor
Model : Intel Core CPU [P1, C2, T7]
Version : 42.07
Mainboard Specific Support : No
Sensor
Model : Intel SNB/IVB IMC
Version : 0.09
Sensor
Model : Intel ICH65 HWM
Version : 0.05
Board Temperature : 49.00°C
CPU Temperature : 44.00°C
MCH/Memory/Board Temperature 2 : 35.00°C
Voltage Sensor(s)
CPU DC Line : 1.056V
System Bus(es) on Hub 1
Version : 2.30
System Bus 0 : PCI
System Bus 1 : PCIe 2.00 x1 2.5Gbps
System Bus 2 : PCIe 2.00 x1 2.5Gbps
LPC Hub Controller #1
Model : Intel H67 LPC Controller
OEM Device Name : Intel H67 LPC Controller
Revision : A6
ACPI Power Management : Yes, Enabled
Advanced TCO Mode Support : Yes, Disabled
RNG - Random Number Generator : No
High Precision Timer Support : Yes, Enabled
No. Precision Timers : 8
System Timer : 14.32MHz
Delayed Transaction Enabled : Yes
Disk Controller
Model : Intel Cougar Point 6 port SATA AHCI Controller
OEM Device Name : Intel Cougar Point 6 port SATA AHCI Controller
Interface : SATA
Revision : A6
Specification : 1.10
Maximum SATA Mode : G3 / SATA600
Channels : 2
In Use Channels : 2, 100%
Port : G2 / SATA300
Port : G2 / SATA300
Audio Device
Model : Intel Cougar Point High Definition Audio Controller
OEM Device Name : Intel Cougar Point High Definition Audio Controller
Revision : A6
Type : HD (High-Definition) Audio
Version : 1.00
No. In / Out / Bi-Directional Streams : 4 / 4 / 0
No. Serial Data Streams : 1
Audio Codec
Model : 32768 0000
Revision : A1
Audio Codec
Model : Realtek Semi Realtek 662 High Definition Audio
Revision : A2
Version : 1.00
Audio Channels : 8
USB Controller #1
Model : Intel Cougar Point USB Enhanced Host Controller #2
OEM Device Name : Intel Cougar Point USB Enhanced Host Controller #2
Revision : A6
Version : 2.00
Specification : 0.20
Interface : EHCI
Channels : 2
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 64-bit
Legacy Emulation Enabled : No
USB Controller #2
Model : Intel Cougar Point USB Enhanced Host Controller #1
OEM Device Name : Intel Cougar Point USB Enhanced Host Controller #1
Revision : A6
Version : 2.00
Interface : EHCI
Channels : 2
SMBus/i2c Controller #1
Model : Intel ICH SMBus
Version : 0.05
Specification : 2.00
Slave Device Enabled : Yes
PEC Support : Yes
Speed : 100kHz
Expansion Slot(s)
J6B2 : PCIe x16 +3.3V Shared PME Full Used
J6B1 (1h) : PCIe x1 +3.3V Shared PME Half Used
J6D1 (2h) : PCIe x1 +3.3V Shared PME Half Used
J7B1 (3h) : PCIe x1 +3.3V Shared PME Half Used
J8B4 (4h) : PCIe x1 +3.3V Shared PME Half Used
Port Connector(s)
J1A1 - PS2Mouse : Mouse / PS/2
J1A1 - Keyboard : Keyboard / PS/2
J2A1 - TV Out : Mini-Centronics Type-14
J2A2A - COM A : Serial Port 16550A / DB-9 pin male
J2A2B - Video : Video / DB-15 pin female
J3A1 - USB1 : USB / USB
J3A1 - USB2 : USB / USB
J3A1 - USB3 : USB / USB
J9A1 - TPM HDR : None
J9C1 - PCIE DOCKING CONN : None
J2B3 - CPU FAN : None
J6C2 - EXT HDMI : None
J3C1 - GMCH FAN : None
J1D1 - ITP : None
J9E2 - MDC INTPSR : None
J9E4 - MDC INTPSR : None
J9E3 - LPC HOT DOCKING : None
J9E1 - SCAN MATRIX : None
J9G1 - LPC SIDE BAND : None
J8F1 - UNIFIED : None
J6F1 - LVDS : None
J2F1 - LAI FAN : None
J2G1 - GFX VID : None
J1G6 - AC JACK : None
Performance Enhancing Tips
Warning 2544 : System/Video shared memory greatly reduces performance. Use external video card.
Warning 2531 : Single memory channel may not provide enough bandwidth.
Warning 2513 : TPM not detected. Some security features are unavailable.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
PostPosted: Sat Feb 03, 2018 1:58 am
BIOS string comes up as an Intel DH61BE or DH61CR which it is not (both are micro ATX boards). It is an embedded/industrial/signage board though with all the white pin ports which are usually COM or used to provided power or signals to flat screens. If you have it powered up and working, the manual won't really be necessary unless you want to use the white ports and require the pinouts. Drivers wise, Windows 7 and upwards 'should' pick all the hardware up - if you use linux, it will pick up all the hardware and just work.
PostPosted: Sat Feb 03, 2018 10:07 pm
Thank you so much for this information Mr T! Yes I powered it up and I'm using this as of this moment. But I really want to have a manual for this board in order to put the correct pinout. Any site or info for manual of this board will greatly appreciated. :)
PostPosted: Sun Feb 04, 2018 6:42 am
Try his link..
https://www.intel.com/content/www/us/en ... h61be.html
or here..
https://www.intel.com/content/dam/suppo ... Spec08.pdf
99% of all data ports are 'standard' per the ISA rules (Industry Standard Architecture).. https://en.wikipedia.org/wiki/Industry_ ... chitecture
However, some manufacturers use the port design 'pinout' differently. If unsure of use, an ohmmeter test from ground to any pin should disclose if 'standard' or 'otherwise'. Do so with no power to the board!!
This site lists almost all port pinouts used with computers.. http://pinouts.ru/
Lots of choices for info, but avoid those "libraries" that want fees or 'members'. And non-authentic sources could be harboring malware.
PostPosted: Wed Feb 21, 2018 4:03 am
@artflo,
I'm curious with the ports between the LAN and the audio, what are they?
Does this thing have 2 serial ports next to the VGA port?
I'm not seeing any SATA ports?
From that I suspect this to be ripped out of a kiosk or Point Of Sale (POS) system, that might increase the challenge of finding info a bit. However, I'm willing to give it a shot.
PostPosted: Fri Feb 23, 2018 10:48 pm
evasive wrote:
@artflo,
if I had to take a wild guess.. eSATA ports.
From what I can make out from looking at the pic..
VGA (dark blue)
Serial Ports (appears to be 2 side by side) [lighter blue]
4x USB header
2x USB/LAN header
2x eSATA Ports
Audio
https://i.imgur.com/Xp4yw0E.jpg
Compaq-Fu Master
