It is currently Tue Nov 20, 2018 8:14 am
PostPosted: Fri Jul 15, 2016 3:48 pm
Hi.
I got Sony Vaio PCV-RZ26G Computer and wanted to reuse case, only problem i got motherboard 20 pin connections are unclear to use .
Motherboard is ASUS P4S533-VL board and 20 pin FRONT PANEL HEADER markings are confusing, here is the actual wires on board
1 2 3 4 5 6 7 8 9 10
11 12 13 14 - 16 17 18 19 20
Row 1 (top - left to right)
1. YELLOW -
2. BROWN -
3. empty
4. empty
5. empty
6. empty
7. GREEN-
8. ORANGE -
9 BLACK -
10. empty
Row 2 (bottom left to right)
11. RED
12. empty
13. BLACK
14. empty
15. empty
16. empty
17. BLUE
18. empty
19. empty
20. empty
Here is similar question but w/o answer.
http://www.pcguide.com/vb/showthread.ph ... -p4s533-VL
Thanks.
PostPosted: Fri Jul 15, 2016 4:24 pm
95% of the ATX 20-pin power connections follow a standard wiring scheme.
Dell and Apple did have different schemes.
Never plug the wrong type into another system, unless you want a lot of sparks and smoke!!
http://www.smps.us/power-connectors.html
Found a link for that Sony model, https://esupport.sony.com/US/p/model-ho ... manualsTab
Click on "System Reference Manual" for "PCVRZ26G_SRM.pdf" and on page 53 is a pinout for the ATX power plug.
PostPosted: Fri Jul 15, 2016 4:31 pm
Thanks but i'm looking for not ATX power supply connection but 20 pin FRONT PANEL HEADER connections with Power Switch, Power LEd, HDD LED, RST and so.
PostPosted: Sat Jul 16, 2016 7:21 am
Could be a diagram of the front panel pinout in that PDF file. But go by what would be logical wire color.. red for hard drive activity, green and yellow for power LED, blue or gray as reset or power switch.
PostPosted: Wed Jul 27, 2016 12:31 pm
green/orange/black is power led, bipolar
red would be the harddisk led
brown/yellow power on if I'm not mistaken
I would need to dig into the archives...
