It is currently Sun Feb 23, 2020 4:16 pm
PostPosted: Tue Mar 18, 2014 5:31 pm
Hi guys
I´ve an old Pc chash System from manufacturer Omron.
The Pc was not Produced from Omron only ,it´s from Manufacturer Trigem
Model TG7701. An old Pc with IDT-C6 Winchip 200Mhz CPU and 256 MB Ram. The old hdd was chrashed (8 .1 GB ide ) and i´ve not found the same new one. Must be changed an new one with 80 GB (found no smaller ). The Bios was from 1997 Ami Megatrend´s an the Number 51-3317-04698-001101111-071595-SiS5597-H .On board was an SIS Chip and audio was an chrsytal audio chip. Contact with Omron ,they says another company use the support for this PC but this support not answer (Torex Germany). Any Ideas to found an newer Bios for this Mainboard ?
The old bios detect my new hdd as 8.1 Gb and the rest ( over 70 Gb) was not working.
PostPosted: Wed Mar 19, 2014 2:37 am
That would be the
Midas: http://www.elhvb.com/mboards/trigem/pro ... D_base.htm
or Woodland+: http://www.elhvb.com/mboards/trigem/pro ... B_base.htm
You might get 32GB out of that disk by setting the capacity limit jumper but not more since the AMI core of that bios cannot handle it. No bios update/upgrade is going to change that.
I would love to have an actual picture of that board as to identify it properly.
PostPosted: Wed Mar 19, 2014 2:56 am
Thanks for Answer.
The picture of Midas Board was the correct . It´s not the woodland one.
The Latest bios found on en old FTP URL from trigem ( Year 1998). I hope i´ve not chrashed this Bios with :-)
PostPosted: Wed Mar 19, 2014 3:47 am
Code:
51-3117-100898-00101111-071595-SIS5597-007_66_SIS5597
Copyright(C) 1997 Xoceco-TriGem Computer Co,. Ltd
This one?
PostPosted: Wed Mar 19, 2014 3:59 am
I think that system is AKA TPS-7500, here's some info:
https://web.archive.org/web/20031228233 ... ps7500.pdf
and some more stuff:
Code:
CPU Frequency Ratio Jumpers
    Jumper Number       Jumper  Setting             Freq. Ratio                    Processor Type
      J8    J5    J9*
                                            2-3    1-2    ---                  2.5                        P54C, P55C, AMD K6
                                            1-2    1-2    ---                  3                           P54C, P55C, AMD K6
                                           2-3    2-3    ---                  2                           P54C, P55C, AMD K6
                                            1-2    2-3    ---                  3.5                        P54C, P55C, AMD K6
* For AMD K6, set J9 to 1-2.
CPU Core Voltage Jumpers
    Jumper Number                    Jumper  Setting             Core   Voltage                Processor Type
    J10    J11    J12    J13
                                                       2-3    ---    ---    ---            3.3V                                   P54C
                                                       2-3    ---   2-3   2-3           3.2V                                    AMD K6 233MHz
                                                       2-3    ---    ---   2-3            2.9V                                    AMD K6 166 or 200MHz
                                                       ---    ---    ---    2-3            2.8V                                    P55C
CPU I/O Voltage Jumpers
    Jumper Numer             Jumper  Setting                Processor  Type
       J14    J15
                                               2-3    2-3                         P54C, AMD K5
                                               1-2    1-2                         P55C, AMD K6
CPU External Clock Speed Jumpers
    Jumper Number            Jumper  Setting             CPU External Clock Speed
    J18    J19
                                                  2-3    2-3                                   50MHz
                                                  2-3    1-2                                   60MHz
                                                  1-2    2-3                                   66.6MHz
Other Jumpers
Jumper  Number        Jumper  Setting                   Function
        J4                                     1-2                    CMOS Keep (Normal)
                                                2-3                     CMOS Clear
        J20*                                1-2                     Selects Serial Port 2 (COM2)
                                                2-3                     Selects MIDI/Game Port
PostPosted: Wed Mar 19, 2014 6:11 am
Here is a link to SIS 55xx model chipsets and BIOS types.. plus mobo providers.. http://www.wimsbios.com/chipset/2A5II.jsp
Probably no success in finding a newer BIOS than what is had. The BIOS has to be tailored to the mobo design, a different one likely won't work.
And as to hard drives, getting a really new drive of less than 100 GB is not easy. You may find some laptop hard drives of less than 100 GB, and they should work with the system if an adapter to standard IDE is used. Set the primary partition to no more than 8 GB, and create an extended partition. In that, you could go around 10 GB each additional drive partition, and it should work. But with only 256 MB system memory, you could not use newer than Win XP as an OS. A Linux system would be more compatible.
In checking my archives, I found nothing newer than what you have for a BIOS.
PostPosted: Wed Mar 19, 2014 7:19 am
Is the PCI slot already taken? Otherwise you may consider using a bootable harddisk controller interface card. They usually can handle larger disks (you need LBA48 support). Something like this:
http://www.newegg.com/Product/Product.a ... 6816124009
Users browsing this forum: YandexBot [Bot] and 2 guests
