It is currently Fri Oct 19, 2018 10:00 am
PostPosted: Tue Aug 20, 2013 10:09 am
Hi All...I have a question..
I have a friend, he asked me to install windows 7 on his pc, but he's still using the old series mainboard (Fujitsu D1761-A22), and i'm having difficult to finding the driver for Windows 7 of this mainboard, I have browsed the fujitsu website and there's only available to windows xp drivers, no windows 7 drivers.
can you all give me solutions ? how can i install windows 7 on this mainboard ?
I'm sorry if i got the wrong room, cause i'm still newbie.
Thank You in advance
PostPosted: Tue Aug 20, 2013 10:58 am
Siemens Scenic P series
http://uk.ts.fujitsu.com/rl/servicesupp ... cenicP.htm
The biggest issue is the network driver I think. ADMtek is no more (website is dead). I did find something that may be a Vista driver and with any luck that might work in windows 7. However I would suggest you buy whatever windows7-supported add-in network card and use that instead.
The rest of the hardware should be picked up by windows 7 using generic drivers.
PostPosted: Tue Aug 20, 2013 4:41 pm
For what it's worth, I would honestly not invest time or money putting Windows7 on that machine..
The absolute minimum ram that will support 7, is 1GB. The max that board can take is 2.. My desktop has 8GB and tends to choke but I have the 64-bit version.
Compaq-Fu Master
