HP Pavilion Custom dvtqe-6c00 using Wistron 664261-009 mb
Postby DanCallaghan » Tue Mar 05, 2013 11:40 am
I own an HP Pavilion Quad Edition Entertainment Notebook PC, model: dv7t-6c00 CTO, Product # A1L77AV. According to HP this laptop is classified as a custom build, which is causing me a lot of problems identifying upgrades. According to HP Technical Repair Center, the motherboard make/model is: Wistron 664261-009, but I can't find any technical specifications on the Internet for this motherboard, and HP isn't much more help.
I'm trying to determine the maximum memory limitations (so far I've determined DDR3 PC3-12800, CL=9, Unbuffered, Non-ECC, DDR3-1600, 1.35V, 1024Meg x 64, 16GB (2x8GB) Kit, SODIMM), and the maximum hard drive limitations for this motherboard (we believe 2TB, SATA II, 7200 RPM, no idea if we can use SATA III), they say I can use SSD drives, but again no idea on the limitations.
The BIOS information is:
InsydeH20 Setup Utility Rev 3.5 (F10)
Product #: A1L77AV#ABA
System Board ID: 1803
Processor: Intel i7-2760QM 2.4 GHz
BIOS Version: F.1B
BIOS Vendor: Insyde
UUID: 5527359E-9FC7-4785-DE5A-082E5F82EB85
Product Configuration ID: 068E210000204620000640100
System Board CT #: PCKVL2B2H1Y1E9
HP's website: bit.ly/Yb2MhB "For the best performance, purchase the fastest memory the motherboard supports." suggests checking motherboard specifications, but those are not provided and even HP tech support cannot point me to where to go to find them.
Any help would be appreciated.
DanCallaghan
Postby Toby B. » Tue Mar 05, 2013 11:59 am
Toby B.
