It is currently Wed Feb 20, 2019 10:00 pm
PostPosted: Tue Nov 22, 2011 12:40 pm
8) :roll: Hello again ,picked up a Decent looking Mobo for $10.00 yesterday. Figured it is time soon to replace my flooded semi-operating Jetway 370 Board.
it is an IBM :oops: says FRU P/N 49P1599
LBL P/N 32p2992
Has a funny Header/Socket on Bottom Called POV 3 (it is a 30 pin connector-like small ide socket).
To the Extreme left of it , is a socket/Header (20 pin ) with 2 jumpers on pins 2+3 ,then 4+5 <looking @top row>.
It is Labeled A_ F_ PANEL -seems like a Mystery to ME??!!
The F_Panel connector /Header /Socket ,I gleaned out from a general Web Search /// Turns out this is a NETVISTA MOBO ,of some Variant.
You guys are great for your advice.
Take care ,stu
"If There was any Economic Justice In this United States We live In , We would All Be Driving Hummers & Eldorados & Magnums and Gasolene would be 10 Cents A gallon !!!"
PostPosted: Tue Nov 22, 2011 1:52 pm
Same motherboard used in 8305 (Netvista) and 8303 (M42) series IBM PCs.
Difficult to find info but I will see if anything is available.
I am guessing your looking for front panel connectivity to power it up?
PostPosted: Tue Nov 22, 2011 1:59 pm
See if this helps. Has pics. FRU is different but it might be relevant to your board.
http://www.pcguide.com/vb/showthread.php?t=49883
PostPosted: Tue Nov 22, 2011 9:49 pm
HMM (Hardware Maintenance Manual) (August 2004) - NetVista 8181, 8182, 8301, 8303, 8304, 8305, 8306, 8307, 8308, 8309, 8310, 8311, 8312, 8313, 8314, 8315:
http://download.lenovo.com/ibmdl/pub/pc ... 4p2969.pdf
PostPosted: Fri Nov 25, 2011 6:47 am
The biggest problem I have with these guides is they don't go that indepth. They say something like "Remove all cables", "Replace all cables"...
PostPosted: Fri Nov 25, 2011 7:40 am
I agree, nonetheless, it's about the best I can deliver at the moment, sometimes the front panel layout is in there, often not and if it has one of the proprietary big connectors you're SOL anyway...
PostPosted: Thu Dec 01, 2011 11:18 am
:? :wink: :-|
just to top off the Proprietary issue ,exploring this thing ,8503 , the AGP videoKard slot is mounted BACKWARDS ,,yes "backwards" -------------
I guess it is /was IBM-Lenovo,s idea to frustrate Computer Builders from recycling their stuff into standard ATX /MATX cases.
With some Cable Fabrication ,I could use my AGP Kard in there , but have to remove metal Slot /header Panel from VGA connector screws/nuts to install
it inside properly.
Regards ,stu
PostPosted: Thu Dec 01, 2011 1:16 pm
http://upload.wikimedia.org/wikipedia/c ... svg/300px-
not backyards, but 3.3 volt vs 1.5 volt.
i think.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
