It is currently Sat Sep 22, 2018 7:18 am
PostPosted: Fri Jul 01, 2011 4:00 pm
Hello computer gurus,
I am in a processes of building a new desktop PC and I am trying to buy the Sata cables that goes into Hard drive and Cd/dvd player for the hard drive cable I am establishing a (RAID) and since I am not familiar with RAID I really need your help, i would appreciate all the help that I get.
and also would really thank you if you can help me with choosing right wattage for the power supply I need for this system.
Thank you very much for your help
here is my system I am putting together:
MB ASROCK|P67 EXTREME4 (B3) P67 R
CASE ROSEWILL|CHALLENGER RT
CPU COOLER CM|RR-CCH-PBU1-GP R
GIFT FUTUREMARK SHATTERED HORIZONS
MEM 4Gx2|G.SKILL F3-10600CL9D-8GBNT
THERMAL GREASE MASSCOOL FANNER420 R
CPU INTEL|CORE I5 2400 3.1G 6M R
(3) HD 500G|WD WD5002AALX % - OEM
(2)DVD BURN SAMSUNG | SH-222AB % - OEM
MS WIN 7 PRO SP1 64-BIT 1PK - OEM - OEM
HERE is the Power supply I have in mined Any opinion's is welcomed.
Thermaltake TR2 W0388RU 600W ATX 12V v2.2 Power Supply
PostPosted: Sat Jul 02, 2011 10:42 am
Looks like it supports RAID natively so your going to see one of two things when you first boot the computer.
Either you'll see a RAID configuration option after the boot screen (usually something like CTRL F8 to Enter RAID config) or it will be in the BIOS in a sub screen.
Just setup a RAID 5 array and Initialize it. Windows 7 setup should take care of the rest. If it needs drivers, they should be included on your system board manual.
600Watt power supply could do it, but you;d probably want something closer to a 750.
