Dell Motherboard ID Needed (Updated)
Postby ssheperd » Wed Nov 24, 2010 8:41 pm
I was given a barely used Dell XPS 410. I have the owners manaul but no information was provided about the system board. Tried Manufacturer ID Links but too many boards appear. Of course I called Dell but they were no help at all. I would like to have information about the board including manufacturer, model number, pin layout, ect. The identifying number that appears on the board is E210882. Also, the following appears on a tag: AA-D37032-306. If I need to offer any additional information please let me know. Any help would be greatly appreciated. Many Thanks! :)
ssheperd
Postby ssheperd » Thu Nov 25, 2010 7:39 am
The Chipset for the board is Intel P965 Express
ssheperd
Postby ssheperd » Thu Nov 25, 2010 7:43 am
The Memory type is dual-channel 533-, 667-, and 800-MHz DDR2. Sorry for the short descriptions. I am trying to get 5 posts so I can submit the URL link for the specs
ssheperd
Postby ssheperd » Thu Nov 25, 2010 7:45 am
Here is the link for the XPS 410 specs:
http://support.dell.com/support/edocs/s ... /specs.htm
ssheperd
Postby Toby B. » Thu Nov 25, 2010 8:22 am
the AA number points to an OEM intel board being the most likely but cant find an exact match
Toby B.
Postby ssheperd » Thu Nov 25, 2010 10:25 am
Thanks so much for responding. At least I know I'm looking for an Intel OEM board. That's a start.
ssheperd
Postby ssheperd » Thu Nov 25, 2010 12:12 pm
Went back and looked at the board and the letters RU appear before E210882.
ssheperd
Postby Hardware Junkie » Thu Nov 25, 2010 1:27 pm
Unfortunately thats probably as much as your going to find out about the board.
It may be an Intel OEM board, but Intel only makes them for Dell. The PSU connectors are different, so they only work with their power supplys, front panel pinouts are undocumented, etc...
If you want front panel pinouts, we can see what's been documented online by third parties, but its not going to be easy...
Postby Hardware Junkie » Thu Nov 25, 2010 1:36 pm
Also according to some Google results, the Dimension 9200 was the same system
Postby Hardware Junkie » Thu Nov 25, 2010 1:40 pm
