Identify K8T800P-8237
Postby TiYogi » Wed Jul 28, 2010 5:16 am
Here is the information from running Belarc
Processor
2.00 gigahertz AMD Athlon 64
128 kilobyte primary memory cache
512 kilobyte secondary memory cache
64-bit ready
Not hyper-threaded
Main Circuit Board
Board: K8T800P-8237
Bus Clock: 200 megahertz
BIOS: Phoenix Technologies, LTD 6.00 PG 09/03/2004
K8T800P-8237-6A7C1DC4AC-00
Chip set : Via K8T800PRO
Looking at the Abit site for this board, I can not find an exact match.
There boards that look similar but not exactly.
The reason I am looking for this information was because I currently am running a Intel P4 3.0GHz and I was wondering if this cpu/motherboad combination would be significantly faster.
If it was I could continue configuring this as my main computer.
SeeYa
Help yourself by helping others.
TiYogi
Postby Copper » Wed Jul 28, 2010 8:42 am
you cant replace that AMD cpu with an INTEL cpu
Copper
Postby evasive » Wed Jul 28, 2010 9:43 am
I know that should be 6A7L1***C as that is the chipset part of the ID code, please reply with the 3 *** from the code so we can do a remote guess as to what that board might be.
The AMD board/CPU combo looks to be on par with your P4 machine, depends a lot on how much memory is fitted as well.
Postby fussnfeathers » Wed Jul 28, 2010 9:55 am
Copper wrote:you cant replace that AMD cpu with an INTEL cpu
He wants to replace his Intel proc and motherboard with the AMD proc and board.
Evasive's right, but without knowing what Intel board you're using now, it could go either way.
Faster than the speed of snot
fussnfeathers
Postby evasive » Wed Jul 28, 2010 11:52 am
@TiYogi: is that still your MS-6743?
http://www.motherboards.org/forums/view ... p?p=711099
Postby TiYogi » Thu Jul 29, 2010 6:00 pm
First of thanks for the replies to my post.
for Copper
I know I can not place a amd with an intel. The mother board has a amd 3000+ cpu on it.
for evasive
What is this "the 3 *** from the code", you are talking about where is it found?
Is it part of the bios or is it the AMD 3000+ number you want?
The audio code number is VIA-3058
The chipset VIA k8t800 Pro
Also you referred to a post about an MS-6743, yes this is currently my main computer.
As far as memory I have 1GB.
So your opinion is that the AMD would not be any different the the Intel P4 3.0GHz I currently am running.
Have I answered the questions or is more clarification need?
SeeYa
TiYogi
Postby evasive » Fri Jul 30, 2010 3:18 am
part from the bios ID string you gave:
But you made atyping mistake there, there is one to many characters in the 6A7C1DC4AC part and the chipset code (the first characters) for the K8T800Pro is 6A7L1 not 6A7C1 after that there's 4 more characters, the last one being C so looking for the 3 positions before that, 6A7L1xxxC where I want the actual characters from the xxx's... If this were to be an Abit board it would look like K8T800P-8237-6A7L1A19C-19 for instance.
I am going to make an educated guess and say it is actually 6A7L1D4AC which would lead to an DFI K8T800Pro-ALF board, looking like this:
Postby fussnfeathers » Fri Jul 30, 2010 5:20 am
Nah, your Intel is better. See if you can dig up another gig of RAM, and run with it. I'm assuming that's a Prescott core, you'll lose Hyperthreading going with the AMD.
fussnfeathers
Postby evasive » Fri Jul 30, 2010 5:28 am
Socket478, the 865GM2-(I)(L)S
http://global.msi.eu/index.php?func=pro ... rod_no=549
supports up to 4GB.
It does support Prescott indeed:
Postby TiYogi » Fri Jul 30, 2010 6:47 am
You did guess right evasive the board does in fact look like the one in the picture.
So this board is not going to be of any improvement over what I currently have. That is the MS-6743/865GM2 with a Intel P4 3.0 GHz with 1 Gb of ram.
My Current computer
Processor
3.00 gigahertz Intel Pentium 4
16 kilobyte primary memory cache
1024 kilobyte secondary memory cache
Hyper-threaded (2 total)
Main Circuit Board
Board: MICRO-STAR INTL, CO.,LTD. MS-6743 Ver1.1A
BIOS: Phoenix Technologies, LTD 6.00 PG 09/17/2004
As far as the memory goes I am not the type of person who tends to run alot of applications at once. I find that 1 Gb of memory is more then enough for me.
So keep what I have and pass along the AMD computer?
SeeYa
TiYogi
Users browsing this forum: Baidu [Spider] and 3 guests
