Intel E210882
Postby AmEv » Wed Jun 16, 2010 7:23 am
Ehrm.... :o Must've slipped my eye.
Thankfully, I have two identical boards, and the other has no bulging caps.
Sheesh, scared myself there. Thought I'd have to go out and spend more money. Phew.
AmEv
Postby Karlsweldt » Thu Jun 17, 2010 7:14 am
Those large caps are easy enough to replace, the only requirement is decent soldering skills plus some solder wick. Never change the capacitance value, or go lower than the voltage rating.. but a higher voltage rating is acceptable. The mobo may still be good!
Electronic circuits prefer pure DC voltages, and any AC ripple on the power circuits can cause all kinds of havoc. The greatest use of capacitors is to ensure a pure DC voltage. Some applications use capacitors as 'couplers', passing AC signals but blocking DC voltages.. as in audio amps.
Postby fussnfeathers » Thu Jun 17, 2010 9:19 am
Fast soldering skills. You don't want a low powered solder stick that needs more than a couple seconds to melt the solder. You'll melt other things along with it. :o
Faster than the speed of snot
fussnfeathers
Postby Karlsweldt » Fri Jun 18, 2010 2:46 pm
fussnfeathers wrote:Fast soldering skills. You don't want a low powered solder stick that needs more than a couple seconds to melt the solder. You'll melt other things along with it. :o
Quite true! Having "decent soldering skills", one would be aware of such pitfalls. With soldering, welding or brazing, you want to "get in and get out" with the heat so as not to damage or draw temper from other components. The smallest soldering iron would be a 50 watt blunt-tip pencil type, or a 75/150 watt gun.
Postby AmEv » Fri Jun 18, 2010 9:48 pm
Well, the heatsink came in two days after I ordered it. Usually happens with us, where we live. It's next-week shipping, and we recieve it two after ordering.
AmEv
Postby fussnfeathers » Fri Jun 18, 2010 11:17 pm
That usually happens with me, too. Newegg has a warehouse just over in Jersey, takes about 6 hours to drive there. What irritates me is when the part gets to my town in two days, and UPS takes it back off the truck, as I paid for standard 7 business days, not two-day shipping.
fussnfeathers
Previous
