HP Laptop DV5 1140-TX CPU Support
Postby BRC » Sun May 16, 2010 4:18 pm
Hello All,
I have been trying to find what would be the fastest processor that i can fit in the following laptop motherboard that i currently have. I have looked around and it shows that Core 2 2.53ghz is the only one available for this motherboard. I am not sure and would like to know if there is any other processors that i could fit on this board that had the same socket. Possibly also graphics card though it looks like its soldered on
Specs:
HP DV5 1140TX
Motherboard: NE591PA
Motherboard product code: 482870-001
Thanks
BRC
Postby BRC » Sun May 16, 2010 6:50 pm
I have found the T9800 cpu that is also a Socket P 478 processor. Im just not sure if it will be compatable with it:
p9500 specs:
http://processorfinder.intel.com/detail ... Spec=SLB4E
t9800 specs:
http://processorfinder.intel.com/detail ... Spec=SLGES
t9900 specs:
http://ark.intel.com/Product.aspx?id=39312
BRC
Postby fussnfeathers » Sun May 16, 2010 7:43 pm
TDP and voltages are too high on the faster two procs. The motherboard won't take those. Generally, when a laptop manufacturer says "these are the only processors" they mean it.
Vid card is also non-replacable, it's not a seperate card. It's a GPU chip with motherboard support to draw graphics memory off the system RAM. You can't replace it. The only laptops with replacable graphics have specific cards (nVidia uses MXM, I forget what ATI uses off the top of my head, but they're not interchangable. Got a high-end laptop with an ATI upgradable card, you can't put an nVidia card in instead.........and, if you want to get particular, not every nVidia card is compatible with every MXM slot).
Faster than the speed of snot
fussnfeathers
