MB Model Fujitsu Siemens Version S26361-D1115 Manual
Postby jarbas » Thu Apr 29, 2010 10:01 am
Hello all.
If you please, I'm in need of the (hard to find) Manual / User Guide for this MoBo, from a Siemens Scenic 500 box.
Code: Select all
MotherBoard:
Vendor: Fujitsu Siemens Computers
Model: D1115
Version: S26361-D1115
On board printing:
Code: Select all
S26361 D1115 G12 GS2
(these last two G12 and GS2 might be a misplaced printing, being S26361-D1115 G12 GS2 in bold printed in white and others in embedded gold color from the board)
Board Serial Number: YBGW1[Demo Version]
This board might also be referred as a Model: S26361D1115G12
The only Spec Sheet I find in this Forum is referred to a Fujitsu-Siemens D1156
More Info
Chipset:
Name: Intel 440BX/ZX/DX (Seatltle)
82443BX/ZX 440BX/ZX CPU to PCI Bridge (AGP Implemented)
Southbridge: Intel 82371EB/MB PIIX4E/M ISA Bridge
System Bus Speed: 100 MHz (multiplier 3.5x)
Co-processor type: Internal 350 MHz
BIOS
Type: Phoenix
Manufacturer: Technologies, Ltd.
Date: 10/26/99
Version: 4.06 Rev. 1.07.1115
ISA: 1
PCI: 3
AGP: 1
Onboard Device SMsC Super I/O
Obs: for some reason I'm unable to enter the Bios Setup on F2 pressing.
The provided info were taken from boot utilities.
I appreciate your help in finding the manuals for this board.
Thanks in advance and my best regards.
jarbas
Postby evasive » Thu Apr 29, 2010 10:25 am
D1115 system board.
http://uk.ts.fujitsu.com/rl/servicesupp ... 120-US.pdf
Try a new CR2032 coin cel CMOS battery...
Postby jarbas » Thu Apr 29, 2010 11:46 am
Evasive,
Before all, thanks you very much for your information.
I took a look on that pdf before and I didn't realize it's the correct one for this MoBo, mainly due to it's reference (D1115-Z120) while mine is a D1115-G12 and also some minor differences on the physical components on it, namely the battery, where on Z120 is placed on the right side of the AGP and on the g12 is slightly on the middle of it.
Because you understand by far much more than I do on these matters I'll take as the only available User Guide and I do appreciate the time you took in giving me a final answer.
I have a couple of old motherboards and I'm trying to grade them (better to not so good) in order to put together some boxes with several purposes in my house.
Best regards to you and, by the way, thanks for the info you give on all posts we can see on this board/forum.
jarbas
Postby evasive » Thu Apr 29, 2010 12:42 pm
If you need any more boards identified/manuals for them, just start a new thread for them. Because that is what this forum was made for :)
Postby fussnfeathers » Thu Apr 29, 2010 2:02 pm
And, if the board in question actually exists, Evasive probably has a manual somewhere in his house. I'm pretty sure he has a pile in his bathroom.......
Faster than the speed of snot
fussnfeathers
Postby evasive » Fri Apr 30, 2010 12:09 am
No that is just the server holding the digital versions. Waterproofing it was a b*tch :lol:
You must have 5 posts before you can post URL's/Links.
Postby jarbas » Fri Apr 30, 2010 10:39 am
:newb: (allowed to insert URLs after 5 posts)
This is the 3rd post :mb_ignore::
:mb_partypeeps::
:mb_hijacked::
:mb_so::
jarbas
Postby jarbas » Fri Apr 30, 2010 10:40 am
This is the 4th post :mb_ignore::
:laola:
:mb_spam2:: alert
jarbas
Postby jarbas » Fri Apr 30, 2010 10:41 am
:mumum:
This is the 5th post :mb_ignore::
:mb_razorwind::
jarbas
Postby jarbas » Fri Apr 30, 2010 10:42 am
fussnfeathers wrote ...if the board in question actually exists...
indeed exists, I have 2 of them, but the UGuide evasive referred to is good enough. In fact might be the only one, after searching whole Internet, going twice to the end of it (S26361-D1115+G12&btnG=Google+Search&) :)
For the sake of 'google searching'
changing the keyboard solved the issue. (funny ... I used one of those folding and cheap ones while the one where F2 is not recognized by the board and/or/probably bios is from a well known brand. So, solution hunters, give it a try...
*cheers*
obs. .... to avoid the 5 posts minimal imposing to use the url links tag. Please remove prior 3 posts. tks :) :mb_hiphurray::
jarbas
