motherboard id help needed
Postby awannabeee » Thu Apr 15, 2010 6:10 pm
hello all;
dell will not help me id a board i got from someone who could not get the machine they made working. those dell people are a trip.
i have s/n and the intel number. i think its an intel number and the cpu
CN-0W2562-48111-436-034R
AAC25595-609
DELL RE .A01
Intel (R) mPGA478B Processor
i need to know the name and mfg. so i can get the manual and wire the thing after i fix the mess the guy made who gave it to me
any help would be appreciated
awannabeee
Postby evasive » Fri Apr 16, 2010 1:35 am
From a Dimension 8300 it seems:
http://support.dell.com/support/edocs/s ... /index.htm
Before you start any use of this board I would advice you to check it for bad capacitors first:
http://www.badcaps.net as this one is a known contender :-(
Front panel, if not using the original casing: forget it. You may want to botch up a functioning header yourself if you like to solder:
http://www.annoyances.org/exec/forum/wi ... 1104628388
look for the posting made by Ben Poehland.
Best of luck.
id help
Postby awannabeee » Fri Apr 16, 2010 3:43 am
thank you so much for your help!
thanks for the advice and the links too.
i have never dealt with dell untill last night on the phone and i will never buy a dell computer and i would advise anyone to stay away from dell. they would not help at all without a tag #.
Asus and HP on the other hand will not only give tech support but also make documentation and downloads available. MSI is also very helpfull.
thanks again.
george PDT_Armataz_01_37
awannabeee
Postby evasive » Fri Apr 16, 2010 10:10 am
you're welcome. let us know if you got it working again or if you need additional help.
mobo id
Postby awannabeee » Fri Apr 16, 2010 10:15 am
are you saying the front buttons will be that hard to wire, if so do you know where i can get the tower for the 8300 for cheap
awannabeee
Postby evasive » Fri Apr 16, 2010 12:57 pm
it's not just the buttons but also USB and audio and whatnot. a total of 34 pins that are not documented very well. Like I said, check out the posting in that thread about soldering things together...
