Athlon X2 and Athlon II X2
Postby olzon » Wed Mar 31, 2010 6:04 am
Hello!
I'm going to purchase a new processor but I'm not sure I'm able to use Athlon II X2 processors with it.
I have a ASUS M3A76-CM, Socket-AM2+
It says in the description that I can use: Athlon 64, Sempron, Phenom II X3, Athlon 64 X2, Athlon X2, Phenom X4, Phenom X3, Phenom II X4.
Since it supports Athlon X2, will I also be able to use an Athlon II X2 processor?
olzon
Postby fussnfeathers » Wed Mar 31, 2010 6:42 am
http://www.asus.com/product.aspx?P_ID=aU8effdifLvraVze
Those are the processors your board supports with the latest BIOS. Check the version, then find a processor that works for you.
Faster than the speed of snot
fussnfeathers
Users browsing this forum: Bing [Bot] and 3 guests
