Intel D850MD replacement
Postby miken100 » Thu Feb 11, 2010 12:32 pm
Can I replace a Intel D850MD Intel 850 Socket 478 micro-ATX Motherboard with a Gigabyte G31M-Es2l motherboard?
miken100
Postby fussnfeathers » Thu Feb 11, 2010 12:55 pm
Sorta. It'll fit your case, yes. Nothing that plugs into the board will work, though. You'll need a new processor, a socket 478 proc will not fit an LGA775 socket, the Gigabyte uses DDR2 RAM, DDR RAM will not fit, your old board is AGP, the Gigabyte is PCI Express x16.....does have onboard video, so you could skip a new video card for now. Main power supply connector on your Intel board is a 20 pin, the Gigabyte is 24 pin. A few other things.
So no, it's not a direct replacement. You need a Socket 478 board with a 400mhz FSB speed, that supports your current processor and peripherals, if you're just looking to replace a bad motherboard.
Faster than the speed of snot
fussnfeathers
Postby evasive » Thu Feb 11, 2010 12:58 pm
Yes, the size is the same.
However:
- you need a new CPU, it is LGA775 and you have a socket478
- you need new memory, yours is RDRAM and this has DDR2
- you can only connect two IDE/PATA devices. Any more will require an add-in card. Alternatively you can replace your optical drives with SATA ones.
- you will need to reinstall your operating system
- you may need a new power supply. Intel boards rarely die out of the blue, usually the PSU killed the board.
Postby Karlsweldt » Fri Feb 12, 2010 12:54 pm
The Intel "845" type mobo may also be considered. Most had a 400 Mhz FSB, some had a 400/533 Mhz FSB. As long as the I/O port plate can be changed out on the case, almost any model micro ATX mobo would fit. But first do an 'eyeball' match as to the mobo mounts. Ensure that only the holes with solder rings top and bottom mate to the mount stand-offs. Most case designs allow the stand-offs to be moved, but if they cannot be moved, then only the original design mobo can be used. Would also be a time to consider a better PSU, one with a higher wattage. The old one may be very tired or barely adequate.
update
Postby miken100 » Fri Feb 12, 2010 1:46 pm
I got the computer running, but the keyboard and mouse will not respond. system boots to the screen that says last shutdown was no good... 30 seconds till windows starts normally. since I can't use the keyboard, it loops and brings the screen up again.
miken100
Postby evasive » Fri Feb 12, 2010 2:00 pm
eew. open case and check for bad capacitors first.
http://www.badcaps.net
Postby miken100 » Fri Feb 12, 2010 2:09 pm
it's a brand new board
miken100
Postby fussnfeathers » Fri Feb 12, 2010 2:50 pm
PS/2 keyboard and mouse or USB? Go into the BIOS and enable legacy USB support if they're USB.
fussnfeathers
