motherboard manual
motherboard manual
Postby Odin1225 » Sat Feb 06, 2010 9:40 pm
I have a laptop and i would like to find a manual for the motherboard so i can figure out what type of sockets i need for the CPU
thank you
Board: Wistron 360B 09.41
Serial Number: 2CE834029T
Bus Clock: 667 megahertz
BIOS: Hewlett-Packard F.24 08/13/2008
Hewlett-Packard Compaq Presario CQ50 Notebook PC F.24
System Serial Number: 2CE834029T
Asset Tag: Chassis Asset Tag
Enclosure Type: Notebook
intel celeron
2.00 gigahertz Intel 575
64 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Not hyper-threaded
Odin1225
Postby evasive » Sun Feb 07, 2010 12:48 am
the service manual:
http://h10032.www1.hp.com/ctg/Manual/c01572022.pdf
You can't replace it with an AMD CPU. This is what is now in there:
http://processorfinder.intel.com/detail ... Spec=SLB6M
Anything intel listed in that manual should fit and will be faster
Postby fussnfeathers » Sun Feb 07, 2010 12:52 am
Fairly sure he's limited to a 667 FSB. 800 or 1066 would theoretically work in a notebook, but would clock back automatically.
Make sure when you start looking for processors, you get a socket P 478. Socket M won't work.
Faster than the speed of snot
fussnfeathers
Postby evasive » Sun Feb 07, 2010 4:38 am
Intel Core2 Duo T9600 2.80-GHz processor (6-MB L2 cache) 489157-006
Intel Core2 Duo T9400 2.53-GHz processor (6-MB L2 cache) 483260-006
Intel Core2 Duo P8600 2.40-GHz processor (3-MB L2 cache) 483259-005
Intel Core2 Duo P8400 2.26-GHz processor (3-MB L2 cache) 483258-006
Intel Core2 Duo P7350 2.00-GHz processor (3-MB L2 cache) 501520-001
Intel Core2 Duo T5900 2.20-GHz processor (2-MB L2 cache) 501522-001
Intel Core2 Duo T5800 2.00-GHz processor (2-MB L2 cache) 501521-001
Intel Pentium Dual-Core T3400 2.16-GHz processor (1-MB L2 cache) 501523-001
Intel Pentium Dual-Core T3200 2.00-GHz processor (1-MB L2 cache) 501519-001
Intel Celeron 585 2.16-GHz processor (1-MB L2 cache) 494285-001
Intel Celeron 575 2.00-GHz processor (1-MB L2 cache) 494284-001
CPU
Postby Odin1225 » Sun Feb 07, 2010 11:40 pm
thank y'all. I have a question if i have pentium 4 CPU can i use it in my laptop? also will my laptop preform any batter with it in?
Odin1225
Postby fussnfeathers » Mon Feb 08, 2010 1:50 am
Which model P4? It might, it might not. And it has to be the right P4 for the socket.
fussnfeathers
Postby Karlsweldt » Mon Feb 08, 2010 1:51 pm
The older Pentium 4 line used different socket types than the newer generation. The original design was 423 pins, later updated to 478 pins. The latest genre uses 775 contacts, in a reverse order of its predecessor. Springy pads instead of pin holes. The processor has flat contacts instead of pins. There is a 'stepping code' on all Intel processors.. so you can positively ID each one as to prowess.
This WIKI link details the different types of CPU sockets used by most computer designs.. since "way back when".
Postby fussnfeathers » Mon Feb 08, 2010 1:57 pm
Socket P 478. We already know that one. :P
fussnfeathers
Re: CPU
Postby Karlsweldt » Mon Feb 08, 2010 2:26 pm
Odin1225 wrote:thank y'all. I have a question if i have pentium 4 CPU can i use it in my laptop? also will my laptop preform any batter with it in?
A laptop model would use a "mobile" type CPU, which draws less power than the standard CPU type. They are designed to go to an idle state whenever possible, to conserve power and produce less heat. Using a desktop processor in a laptop may overload its power supply, and create a too-warm environment.
Postby fussnfeathers » Mon Feb 08, 2010 3:37 pm
won't even fit in a lappie. P4 desktop processors have the heatspreader over the core, mobile P4 processors do not.
fussnfeathers
