It is currently Thu Sep 20, 2018 2:53 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Jan 22, 2010 12:29 pm
Tough because i saw an old thread on this that went nowhere... Now i'v reopened that can of worms!...Long story short.. my m8 has lent me a desktop pc ..until i have rebuilt my new rig. This mobo in here is a nightmare. Who made it? What is it?.. wot can i do with it?. I'm sure i can use some of the hardware. All as follows:
SETUP: (this is open for debate)
Mobo: Could be ECS or MSI Goes under Gateway, Emachines and HP
(this is in an Emachines branded case E4202 so thats where i started)
Board description is RC410-M Rev 1.1 Thats in big letters for kids ..just above the ram slots.
Processor: 3.0Ghz / 800Fsb / 2M L2 Cache /SL94Y... Thats on the chip.
Memory is reported under Sandra and CPUID as 1 gb pc 6400 / 800MHz.... although is supposed to be ddr2 533 1 gb unbranded (result there maybe) Windows only detects as 896 mb though ... new clean install of xp home edition .. previously had vista basic i'm told..
A manual for this might be worth a read 4 me.... Any1..???
PostPosted: Fri Jan 22, 2010 12:34 pm
http://h20000.www2.hp.com/bizsupport/Te ... =c00638516
Compaq-Fu Master
PostPosted: Fri Jan 22, 2010 12:35 pm
http://www.motherboards.org/forums/viewtopic.php?p=645189&sid=28760623a62e8ce2f751abb59895114e
PostPosted: Fri Jan 22, 2010 12:49 pm
Thanks toby...
Can i upgrade to a better processsor then.. its a bit dutch to me ..not fully understanding that cpu support stuff ..sorry.(newbi).. i already got that page thanks shows support but to me at mo its unsimplified chinese.. and that memory issue .. is it because its not a recommended upgrade ..?
PostPosted: Fri Jan 22, 2010 12:52 pm
the -M is ECS. MSI versions are like RC410M-L
There is a manual kicking around, just tucked away inaccessible at the moment...
Compaq-Fu Master
PostPosted: Fri Jan 22, 2010 1:05 pm
http://support.pcworld.co.uk/Uploads/%7 ... manual.pdf
Compaq-Fu Master
PostPosted: Fri Jan 22, 2010 1:21 pm
thank god for adobe reader.. this borrowed rig dont have it ..... ooooo.. scary.. just got latest reader update toby.. be rigth back.. after i can read that pdf..!!!
PostPosted: Fri Jan 22, 2010 2:00 pm
Read it now and loved it.. that tells me all i need to know ...... apart from why is that mem only read in windows as 896mb.. not 1 gig...it all says its faster mem DDR2.. but as with most/all mem . backwards compatible yes.?
PostPosted: Fri Jan 22, 2010 2:05 pm
That I am not sure of..
Compaq-Fu Master
PostPosted: Fri Jan 22, 2010 4:57 pm
As long as the board supports the RAM, it's compatible. Do you have two different sticks of RAM in there? CPUID has tabs for each memory bank. It's entirely possible you have a stick of DDR2 800 in the first bank, and DDR2 533 in the second.....as far as Windows showing only 896mb, Windows allots a percentage of RAM for OS use only, hence the typical "Windows may report lower than installed memory" warning, typically you just see that when installing 4GB, as the OS will only report around 3.2GB. CPUID and such will report the full, correct amount.
Faster than the speed of snot
