need help on compatibility
Postby gesa » Sun Sep 27, 2009 5:13 am
hi
does anyone know whether Intel Desktop Board D865GLC supports 3.0 gb/s data transfer sata hard drives ?
pls advise
thanks
gesa
Postby evasive » Sun Sep 27, 2009 7:39 am
SATA2 is backwards compatible so if fitted they will run on this board on SATA1 speed because that is the maximum this board can handle. Some disks need to be specifically set for SATA1 with a jumper or with software. Check before buying them.
Users browsing this forum: Google [Bot] and 2 guests
