It is currently Mon Aug 20, 2018 9:26 pm
 Post subject: Unidentified MB...
PostPosted: Sat Jun 20, 2009 5:47 pm
I have been trying to identify this MB. A few close encounters, but no real luck.
The identifying factors:
tannish-orangeish color
Orange heatsink on chipset saying "T-Bird Amd k7"
SIS 730s chipset (under heatsink)
"rev. 3.0" in bottom corner
Unfortunaltely, I am not able to get to POST.
PostPosted: Sun Jun 21, 2009 12:06 am
any other marking print on the board, might be some number printed between the white pci slots
possible pc chips M810L V3.0
http://www.pcchips.com.tw/PCCWebSite/Do ... =6&LanID=0
PostPosted: Sun Jun 21, 2009 2:51 pm
Welcome to Motherboards.org!
May be similar to what is described in this link. If the processor mounts in a long slot, then it may be the version. There also was a version that used the AMD "A" socket type, similar to the Socket 370 but pinned differently. This WIKI link describes most of the CPU socket/slot types.
AMD had several lines of older processor types.. the Duron, Athlon and Thunderbird. The "K-7" line was the next advance from the Socket 7 version, or "K-6". Intel had the Slot 1 SECC type CPU mount, and AMD had the Slot A SECC type CPU mount, a mirrored version. No, they are not interchangeable! But about the best speed from that older mobo may be around 1 Ghz.
PostPosted: Sun Jun 21, 2009 9:22 pm
It is Socket 462.
Amd Althlon 1.2ghz
Got just MB. No case.
To Copper:
Nada. Only FCC approval stamp above, and CE approval and checkmark in between.
PostPosted: Mon Jun 22, 2009 7:44 am
It sounds like a board out of the M810xxx series released by PCChips/ECS. All and any info is here:
http://radel.inet.net.nz/m810lmr.html
I suspect the capacitors have gone, several models of this board were made using cr*ppy caps. http://www.badcaps.net to identify if they are indeed bad and what to do about it (in this case recapping will cost more than a replacement board).
PostPosted: Mon Jun 22, 2009 10:49 am
Haha.... Thought so. I put a voltohmmeter to what I thought was the faulty cp, and bam! faulty. Gonna put a request in.
PostPosted: Tue Jul 14, 2009 9:57 pm
...nope...
That ain't it. The floppy and IDE connectors are all in line. Not tall, but the other way.
However, that IS the heatsink, so we're getting somewhere :)
*I stand/sit corrected. Downloaded the manual you suggested, and it is a 100% match, down to the last jumper switch. :oops:
PostPosted: Tue Jul 28, 2009 7:40 pm
Got pix... Who should I email them to?
