Help with a gateway E210882 Motherboard
Postby evasive » Tue Nov 11, 2008 12:03 pm
check positions 3&4 in the serial number :)
Thanks to all
Postby brange » Wed Nov 12, 2008 7:06 am
I am eternally grateful to all of you for solving my problem. You all are great. :P
brange
Cannot get this board to power on!
Postby speedyme » Mon Oct 05, 2009 10:58 am
I ordered a new board because the old one went bad. After installing the new one it wouldn't power on so I had another one sent assuming the board was DOA but now this one is doing the same thing.
New mobo will not power on! I have tried all variations of pins using a jumper because I thought the switch might have gone bad but still no signs of life.
I checked/tested power supply. It is good. But I cannot for the life of me get this thing to come to life.
PC info: Gateway 556Ge
Board info: E210882
I wonder if there is a step I am missing. Anyone got any ideas?
speedyme
Postby evasive » Mon Oct 05, 2009 11:21 am
That is the AG91510J.15A board known as the Intel Augsburg D915GAG board.
Please test the board/CPU/power supply outside the casing and see if you get any beeps.
Can you please reply with the AA or PBA xxxxxx-xxx part number (should be on there somewhere) and the S-spec code from the CPU you are using? To verify your revision can run the CPU you are using.
Previous
Users browsing this forum: Majestic-12 [Bot] and 3 guests
